Mark Rejhon
- Jul 6, 2004
1440p is the way to go for graphics, programming, and desktop use (and slower action gaming).I loved my samsung s27a950d. But I am wondering if the catleap 27" 1440p monitor is the way to go now.
What do you s27a950 owners think? Is 1440p the way to go?
However, LightBoost is the way to go if you primarily do faster-action video gaming on your monitor. More competitive advantage!
Also, the S27A950D has an undocumented strobe backlight mode (though Samsungs are not good for input lag for this):
Samsung Zero Motion Blur HOWTO -- Works on 700D / 750D / 950D
PixPerAn Tests on LightBoost monitors (I own both BENQ XL2411T and ASUS VG278H)
baseline - 60 Hz mode (16.7ms frame samples)
50% less motion blur than 60 Hz (2x clearer motion) - TN 120 Hz mode (8.33ms frame samples)
60% less motion blur than 60 Hz (2.4x clearer motion) - TN 144 Hz mode (6.94ms frame samples)
85% less motion blur than 60 Hz (7x clearer motion) - TN 120 Hz mode with LightBoost set at 100% (2.4ms frame strobe flashes)
92% less motion blur than 60 Hz (12x clearer motion) - TN 120 Hz mode with LightBoost set at 10% (1.4ms frame strobe flashes)
Versus:
40% less motion blur than 60 Hz (1.7x clearer motion) - IPS overclocked to 120Hz (8.33ms + excess pixel persistence) -- Test done by Vega
This really clearly shows that not all 120 Hz is made the same. There is 7x less motion blur on a LightBoost-enabled 120 Hz TN than an overclocked 120 Hz IPS. Stroboscopically shortening the individually refreshes without increasing the refresh rate, makes a massive difference in motion blur elimination for people who are sensitive to motion blur, and want the "CRT silky smooth effect". As long as your eyes are comfortable with CRT >85 Hz.
