Also the 950 enclosure is just plain ugly, lets be honest. It looks so modern and chic.
It's a matter of opinion, I quite like the design.
Hey guys,
My new S27a750D is getting delivered tomorrow. I could use some guidance in setting it up.
My plan is to make the 27" my primary monitor. My current Acer 24" 120hz will be the secondary. The 27" will be hooked via displayport of course and the Acer using the DVI port.
Is it pretty simple to make the displayport the primary? I'm assuming its just a few clicks in Catalyst Control Center? If not your help is appreciated.
thanks
Now I can't get the monitor to work at all on Displayport. No combination of old or new cable will get it to turn on at all. My next step is to replace the mini-DP to DP adapter, but if that doesn't work, what do you suggest? Is my video card toast or is the monitor bad?
Well, I hooked up my new monitor last night. I'm only had time to play with it for about an hour. I am posting in hopes you guys can save me some time clicking around in menus trying to fix a couple issues...
Oh, first off the monitor is BRIGHT. Maybe too bright but jury is still out on that. It makes my Acer 120hz look dark and dull. So right there it's definitely an upgrade.
Here goes my questions.
- My biggest issue is my 24" Acer 120hz LCD. It is hooked to the DVI port and it is running at 60hz. I have it set as secondary monitor with the desktop set to extend onto it. I'm not sure why it won't let me set it to 120hz considering its the same port it was connected to when it was my primary monitor. I also couldn't get Win7 to accept the Acer driver for this monitor. It's seeing it as a standard monitor and using the default windows driver.. When updating driver under device manager I point to the ACER drivers download for this monitor and it tells me the best drivers are already installed, strange. I'll be re investigating this later. Just wondering if anyone else has ran into this issue with two different brand/size 120hz lcds.
- Is extend the best options when using two monitors? I was thinking I could be playing a game on the 27" and say surfing the web on the 24" during downtime (level loading, etc) during a game.
- Any recommended video (picture quality) settings for this monitor yet? I'm not one that will fiddle around in the display properties windows trying to figure out the ultimate settings. I usually let the pros figure that out.
- Any other obvious menu settings (on the monitor) I need to set? I did set the monitor to fastest already.
That's it so far.
thanks
Hmm, first I would buy a straight through cable, mini-DP to DP and see if that works. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10246&cs_id=1024606&p_id=6007&seq=1&format=2
If you have tried that or if it doesn't work then read on.
Well the easiest test is to try a different video card or monitor but those are not always available to folks.
So, do you have an HDMI cable and video card with HDMI out? I'd start there and see if that interface works. If the monitor is new and the videocard is older and has worked fine up till now, I'd suspect the monitor. Unfortunately, if I'm guessing correctly, you don't have a spare monitor or videocard that uses displayport so you may have to just roll the dice and take advantage of your warranty/s. BUT FIRST I'd call customer support and see what they say.
I remember reading somewhere that there is a problem with the fan freezing. I don't remember if this is with the 750d or the 950d. But I suspect it might be the unit overheating. I hear the fan running, but the base is getting quite warm.
Last night, the monitor went black on Displayport and no matter what I did, I could not get it to come back on. This morning, after the monitor had been off all night, Displayport came right up first try. I haven't had a chance to test this out further... but I can't find the forum post or article that talks about the fan issue... does anyone have information on this?
I was concerned about this immediately as well. Just 15-20 minutes after turning them on for the first time, the base was noticeably warm and I heard the fans running on all three displays. Vega's mod keeps looking easier and easier to me. Thinking about getting those PCBs in the open air![]()
Will TigerDirect be getting this monitors back in at their advertised sale price of $399? When I search for the monitor on their site it now says "We're sorry, the product you have searched for is no longer available for sale." I didn't want to pay an extra $100 for it on Newegg but I can't tell if this message means they are out of stock or they are not getting any more PERIOD.
The DP Link error/Out of sync thing happens so often that I doubt all of our videocards are faulty. I actually found a site that somewhat explained the problem. Saying Windows7 recognizes the monitor as a plug-n-play device. You can confirm this by hearing a beep used for connecting a USB device, when actually turning the monitor back on after the well known black screen.
http://superuser.com/questions/120983/how-to-disable-monitor-auto-detection-in-windows-7
As far as I know there is no fix yet. It really does suck.
You sure thats not driver related?
I have the 750 and I love it. I was toying with this or the Dell 2410 IPS for ages but in the end went for the Samsung.
Mine has 1 dead pixel and 'some' backlight bleed in bottom left and right. I coudl live with it as its hardly noticable but I have just contacted Samsung and they are coming to pick it up tomorrow to inspect, repair/replace.
So I cant find this monitor for sale ANY whereAnyone know where I can get one new?
Also I was planning on removing the base and the plastic bezel and running the monitor with heavy duty 3M tape attached to my ergotron mx articulated stand. Anyone take apart this monitor?
FWIW I took a gamble and purchased this dual-link DVI to mini-DP converter with hopes of being able to run 3 of these hogs from a 7970 (2 via DP and one via DVI). It worked, but maxes out at 60Hz meaning no 3D. Frankly, I pretty much expected there to be some sort of problem, if not in the refresh then with sync across the 3 displays. Back to the shop it goes!
AMD cannot release a 3+ DP card soon enough...
Hey I'm receiving this monitor on Monday. Is it possible to run 120Hz on one monitor with an mini-DP to DVI? This is what's my determining factor whether I should ship it back or not :/. It sucks my card doesn't 560 ti doesn't support DP.
Discontinued? Is there a newer/better model to replace it, or did they give up on 120 Hz LCDs?
Has this monitor been discontinue? NO!!!! I also bought one with the intention of buying two more for a 3 monitor setup
