Looks like they are back in stock at tigerdirect for $399.99
Not sure where you saw that, but:
THIS ITEM IS CURRENTLY UNAVAILABLE
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=982706
They took my order but had no stock at the time.. nice of them eh? Well, cancelled that one. do i bite the bullet and get them for more from egg? I psyched myself up already just to have my dreams squashed.![]()
Can anyone tell me if using a dvi to displayport adapter will run this @ 120hz?
Bounty4321: Are you using the specific TriDef that came on the CD, The Updated Specific for this monitor TriDef downloaded fomr Tridef, or the full retail version?
Also what video card are you using?
So I had the DisplayPort Link Error before, and right now it seems to happen very often when I alt tab out of my game. The screen goes black to switch towards my Desktop, and frequently stays black due to the DisplayPort error kicking in.
It does not seem like a cable error to me as it happens pretty often and I can pretty much trigger it. Problem is I dont have any idea where to look.
I'm in the same boat except mine happens in-game or randomly at the desktop. I bought a new video card just to use DisplayPort and so far it's absolute shit.
I'm using the Mini-DP to DP adapter that came with the video card, and the DP cable that came with the monitor. It runs fine for up to an hour, then I'll get weird sync artifacts, then a black screen. The only way I can get out of this is by unplugging the DP cable and plugging it back in.
nvidia card = yes
amd card = no
Ok thinking about buying this monitor for the sole purpose of 120HZ gaming. I am using an ATI 6990 and wanted to check/ask- will the video card/lcd combo work for 120HZ and is there any extra cables that I need to order that might not come with the monitor? The ATI card has like 5 different cables/adapters that came with it and I got plenty of HDMI Cables but from what I understand I will need a display port cable to use 120 HZ? And just another thing- if I get this LCD and want to use 120hz I have to stick with ATI video cards (won't be a problem since that is what I have 90% of the time)
Yeah I use the exact same setup, same adapter and DP cable.
It is really annoying and I don't quite now what I can even do about it. But it happens much too frequently.
Someone said pressing the Source button upon the error fixed it for him, but I've tried and it still happens to me. Really annoyed by it now.
You have to stick to cards that have DisplayPort. Nvidia's current offering doesn't have it, but I'm sure their future cards will. So, technically, no you're not locked into ATI forever.
I found a temporary fix...
In the Catalyst Control Panel, you can adjust the frequency that your desktop operates at. I set it from 120Hz to 100Hz and I haven't locked up yet. It looks like at 120Hz, there's just too much data to push through the crappy DP cable that came with the monitor. This'll work until I get a replacement cable.
Hopefully this works for you as well.
how do I watch movie in 120hz mode? For some reason when I"m watching a movie it feels like a 60hz monitor.
And yes this monitor is freaking awesome. This is coming from someone who has had a Sony FW900 for years. I consider myself pretty sensitive to ghosting and input lag. The image quality is not IPS but still fantastic none the less. This monitor has finally allowed me to retire the Sony FW900. That mofo takes up a lot of desk space.
I have both the FW900 and A750D sitting right next to each other here. While the 750D is about as good as it gets for LCD, the FW900 still blows any LCD out of the water for motion.![]()
Yup I agree but the 750D is the first LCD out of the many I have tried that is closest to a CRT feel.![]()
samduhman:
- 950D and 750D are same panel, different enclosures. 950D has a DVI-D port, 750D does not.
- You can use a miniDP to DP cable, or a DP to DP cable with an adapter (should have come with your 6870) I bought one of these.
- Yes, it will work with that card.
Thanks! I don't see having the different enclosure and a dvi-d port making it worth $200 more so I guess I'll shoot for the 750D.![]()
Will TigerDirect be getting this monitors back in at their advertised sale price of $399?
