Samsung may unveil a true 'zero bezel' TV
GoodBoy
I have a 4k LG tv I bought about 3 years ago and it doesn't have a bezel (pretty sure, I'm at work atm)...
old news?
Also, it's thin as shit glass screen, 65". And you guys are worried about not having a bezel?
Susquehannock
My local news station needs this instead of the 4 panel set up they use now. Completely forgot about my bezel. Now I keep staring at it. Thanks a lot! :cautious:
notarat
I don't understand the hate of bezels.
I mean, sure, by all means, make them small or make them go away, but unless you are doing a multi-monitor setup, or are EXTREMELY space limited, I'd think that you give up more than you gain by going ultra-thin and bezel free.
A bezel drove drunk and KILLED MY FAMILY!
Jagger100
Now bevel-less tech to combine multiple panels into a larger monitor may have some actual application. The problem with a wall-size TV, if you have one bad spot, you need to replace the whole TV. If you can subdivide the panels, then instead of replacing a 16'x9' $10,000 panel you replace a 1'x1' $100 panel. (numbers rectally extracted to make a point)
notarat
Never keep pointy things in your rectum. ;)
Darunion
But would you really expect the industry to move toward letting you do this? They would want you to buy a new tv just to get disney+ supported lol
bigdogchris
My parents have a 720p Panasonic (I think) Plasma from 2005 or so and it has some pretty bad burn-in from news banners at the bottom it looks like. Hows yours holding up?
Great. I've always used it with HD content and rarely 4:3 so there is only a minuscule amount of side bar burn in. I don't game nearly as much as I use to before getting it so that really isn't an issue, plus many games are very UI light now days. It also has a pixel orbiter which I'm sure helps a bit. I think the newer generation ones were better at preventing burn-in, but the thing is huge and gets hot so I totally understand why they were killed off.
sharknice
I have a an old 46" with huge 3" bezels. It looks like a 52" when it's off.
HeadRusch
...meanwhile everyone wants to buy Samsung's "Frame" edition so they can digitally render bezels around artwork you can download yourselfs.....
Darunion
still dont get why people have a problem with bezels.
Marketing departments tell everyone that they do. When in reality it's just down to personal preference. I like a small bezel, pretty happy with my mbest monitors, bezel super close to flush with height of lcd. For my tvs, i get more upset about poor port placement than the bezel. Or only certain hdmi ports are capable of 4k and/or hdr crap.
