cageymaru
- Apr 10, 2003
Samsung is launching a Linux on DeX beta for certain Samsung smartphones. The Note9 and Tab S4 are the first phones that Samsung has officially sanctioned to be allowed to run a Linux environment and connect to a monitor with a single cable for a PC-like experience. This will allow users to bring their PC anywhere their Samsung smartphone can fit. There are certain limitations to the program at this time. Only the Note9 and Tab S4 are supported and Ubuntu 16.04. There is wording that alludes to unsupported distros.
Apps and programs should be built for ARM 64-bit. At least 8GB storage and 4GB RAM is required in your device for downloading a Linux image. Linux on DeX runs only on Samsung DeX and you may need peripherals such as monitor, keyboard and mouse to have a full experience. Terminal mode can be run outside of Samsung DeX mode. Only use authorized images provided directly through Linux on DeX. Other versions or unauthorized images may not operate properly.
