- May 18, 1997
The latest rage is voiding your HTC VIVE and PRO's warranty by ripping the fresnel lenses out and replacing those with the clear lenses from the Samsung Gear VR headset that you would use with your smartphone. The upside is that you get rid of some of the banding associated with fresnel lenses of the VIVE, but the downside is that you lose some field of view and of course you probably want to do this work in a near dust free environment. There are some software issues you have to work through, which are not incredibly difficult, and you will need to have some parts 3D printed to install your new lenses in the VIVE. It looks to be near impossible to get rid of barrel distortion doing it this way, but some folks are getting very close to perfect and a lot of folks seem to like the non-fresnel view much better. There is another build video here for the non-PRO and the guy includes all the links for outsourcing the 3D printed parts as well. And most importantly, a lot of VR gamers are finding that the tradeoffs are good with them. Thanks Monte.
Check out the video.
