So I just got the 950 Pro finally, I've installed it and so far so good. It's recognized on my board and in Windows 10 (installed on my SATA SSD), I installed the NVMe Samsung driver and that's about it. Now I want to clone my Windows 10 install to the 950 Pro, but I'm not sure if that would (easily) work coming from a SATA AHCI device with CSM enabled to a PCIe NVMe device which needs CSM disabled for intended use.
I'm going to try cloning it and startup repair will undoubtibly kick in. Does anyone have experience with a likewise change ?
EDIT: cloning with Macrium Reflect Free worked, it booted up without any hitch. Now I'm going to try disabling CSM but it was so fast booting up, I don't know if it will matter much.
please post your last bios time screenshot:
on the system in signature the last bios time is 18.2 seconds![]()
Is upgrading to this from a Vertex 4 worth it?
Windows is pretty fast now and I would be disappointed if this didn't really make a real world difference after spending a bit of money on it.
I personally notice Fallout 4 loading faster with the 950 Pro 512GB than my previous Samsung 830 250GB, which was no slouch. And I notice the two cables missing inside my case. That's about it.
Install went easy enough, though it took me a solid twenty minutes to figure out I had to boot my Win10 USB stick with UEFI.
Windows takes longer to boot than with my regular SSD, and I don't have any CSM options on my board (ASRock Z170 Pro4), so if anyone has any tips I'd appreciate it.
if you dont ahve any CSM devices disable it in bios...also just leave your PC on....the 20 bucks a year wont kill you or the envirorment
It's more the point of it. It shouldn't be slower to boot than my old Crucial M4.
I'll keep messing around with it tomorrow. I'm probably missing a setting somewhere.
Since I needed the extra capacity, the 325 was well worth it, yes.Worth $200+?![]()
I cloned my drive with Macrium Reflect Free, it was fast and easy. The first thing I did was install the Samsung NVMe driver found on their website and reboot, so it gets loaded. Then I installed the latest Macrium Reflect and with both my SATA drive as Windows 10 boot and NVMe drive as "uninitialized", I started a Clone Disk operation in Macrium Reflect. After that, shut down, remove the SATA drive and boot up. It started without an issue.What's the consensus on a Windows 10 install? Do it fresh or migrate with the Samsung software? And is the CSM feature I've read about a few times in here ASUS-specific? I don't see anything on my ASRock board.
When introducing the 950 Pro, Samsung assurred us that it could manage its heat output. They were right: the 950 Pro achieves a delicate balance where it will almost never overheat from a typical consumer workload, but almost any stress test can trigger sometimes severe thermal throttling. That isn't to say that the heatsink will never help in the real world; those situations are just rare, and even with the thermal throttling it would only take a few minutes to read or write the entire drive. For example, with a heatsink the 512GB 950 Pro is capable of saving an uncompressed 4k 60Hz video stream in realtime, but it'll fill up in six minutes. Other bulk data manipulation like file system or virtual machine snapshotting could be sped up some with a heatsink (provided the task consists of more than just random reads), but in general for consumer hardware and workloads the only source or destination for data that can keep up with the 950 Pro is RAM or another SSD.
So I had an easy transition from an Intel 730 480GB SSD to the Samsung 950 Pro 512GB using the Samsung Data Migration software. It copied the 30-40GB that I had in probably around 1 Minute. Took the Intel 480GB out and turned the system on and it was up and running.
My system is slow to get through the bios though. I think it's mostly due to the fact of having 14 cores and 32GB of ram.
Last BIOS Time: 27.0 Seconds
MSI Fast Boot enabled
Samsung Magician says I'm doing 2343 Read and 1545 Write
ocz presented a drive that may be considered before buying a 950 PRO.
said nobody ever. OCZ is complete crap quality. Or was, before toshiba or whoever it was bought their assets. Still crap until proven otherwise.
i have 2 of these in my case. It might not fit yours but just thought i would mention them.
