DryFire said:If you overclock it seems the opteron would be the way to go. If you don't, the extra cache in the opterons probably won't overcome the 200mhz clockspeed difference (except for in a a few applications).
nst6563 said:And yes, an XP-90 is good enough to cool either. It's not the best, but mine got me to 2.7Ghz running dual prime's at a load temp of 46c.
