cokewithvanilla
- Aug 28, 2013
I am by no means an over clocker, but i decided to mess with my 1700x / Crosshair VI a bit
First run Cinebench R15
stock - 1485
Second run OC 3.68 ghz, minor dram overclock (1.02 bclk, something like 2175mhz)
1552
Third run, 3.8ghz
1485
Fourth run 3.9
1450
fitth run OC 3.68 ghz, minor dram overclock (1.02 bclk, something like 2175mhz)
1425ish
final run, stock
1360
Temps never read over 60 degrees in ryzen master. Never experienced a shutdown or any issues
I am running the latest bios. Corsair H110i, Corsair Dominator platinum 3000mhz ram
The only reason i can possibly see my results suffering after ocing is if i had damaged something. I do not see how that is possible with these mild clocks.
stock - 1485
1552
Third run, 3.8ghz
1485
Fourth run 3.9
1450
1425ish
final run, stock
1360
