Ryzen Linux users. My 1700 won't go faster than 3000 MHz
Discussion in 'AMD Processors' started by hondaman, Apr 18, 2017.
  1. hondaman
    hondaman The OG Hondaman
    71
    Jul 31, 2004
    Currently using Ubuntu Mate 17.04. With 100% load using "stress --16" none of my cores ever go faster than 3000 MHz. In Windows 10 it works fine.
    Has anyone else observed this behavior and how did you fix it?
    Asrock Taichi with 2.0 bios, Ryzen 1700, EVGA ram @ 3200 and Corsair 115i AIO
  2. drescherjm
    drescherjm [H]ardForum Junkie
    14,527
    Nov 19, 2008
    Maybe you need a more recent kernel. I know that 4.10 has fixes specifically for ryzen.
    DooKey likes this.
  3. hondaman
    71
    Jul 31, 2004
    I'm using the latest that ships with Ubuntu, 4.10.0-19-generic. I guess I could try the -RC kernel. I did find someone else that has my problem though (thankfully)
    https://bugzilla.kernel.org/show_bug.cgi?id=195275
  4. nunosilva
    nunosilva n00b
    16
    Aug 6, 2013
    Maybe disabling the cpufreq stuff (power management) will help, or at least point you somewhere (like pstate overclocking in the bios).
  5. LigTasm
    LigTasm [H]ardness Supreme
    4,993
    Jul 29, 2011
    I'll check mine tomorrow when I get home, I didn't even think to look as I haven't had much time to use it. I had a hell of a time getting the 4.10 (non-rc) kernel working with my Nvidia card and haven't had a chance to do anything else.
  6. hondaman
    71
    Jul 31, 2004
    I have updated to the latest mainline kernel, 4.11 and disabled cool and quiet. It still won't go faster than 3000 MHz
  7. Topweasel
    Topweasel [H]ard|Gawd
    1,508
    Aug 12, 2005
    I am confused. Isn't this exactly what is supposed to happen?
  8. likewhoa
    likewhoa Limp Gawd
    412
    Jul 20, 2006
    I got my Ryzen running at 3750 stock voltage in Gentoo Linux with the gcc-6 compiler using -march=znver1 no problems. I am currently moving voltage up to see where my wall is.
  9. hondaman
    71
    Jul 31, 2004
    It should boost to 3.7
  10. Nobu
    Nobu 2[H]4U
    3,280
    Jun 7, 2007
    Reporting of actual processor speed is incorrect when certain features are enabled in bios (think power management?), when overclocking via bclk (iirc). Same happens on Windows if you open task manager's performance tab.
    If your performance in benchmarks improved then the overclock held fine, it's just not being detected properly.
  11. Nobu
    Nobu 2[H]4U
    3,280
    Jun 7, 2007
  12. hondaman
    71
    Jul 31, 2004
    I'm not overclocking. I'm using (mostly) stock bios settings. Only things I've changed is turning on stuff like IOMMU, virtualization and such. All the power management and clock settings are stock.
  13. Nobu
    Nobu 2[H]4U
    3,280
    Jun 7, 2007
    I realized that after posting, thus my second post (above). If you load all cores on your 1700 you'll only get 3.0GHz, or 3.5GHz if you have a 1700x. You'll need to oc if you want all cores at 3.7GHz under full load.
  14. hondaman
    71
    Jul 31, 2004
    Why then do I get burst speed to 3700 under windows 10, but not in linux?
  15. Nobu
    Nobu 2[H]4U
    3,280
    Jun 7, 2007
    On all cores, with all cores under heavy load? In hwmonitor or some other program?
  16. hondaman
    71
    Jul 31, 2004
    On any core. One core. As observed in cpu-z
  17. Nobu
    Nobu 2[H]4U
    3,280
    Jun 7, 2007
    With something running on all cores? Sounds like it's working in windows, yeah.
    How are you observing the core frequency in Ubuntu? "cat /proc/cpuinfo | grep MHz" or similar?
  18. hondaman
    71
    Jul 31, 2004
    Yes
  19. Nobu
    Nobu 2[H]4U
    3,280
    Jun 7, 2007
    Try bapm=1 in the kernel boot parameters.
