Retsam
- Sep 2, 2005
I just have a quick question. New ryzen 3600 build with a just ordered B450 mobo.
Which memory is better overall. DDR4 3200 cl14 sam b-die or 3600 cl16 sam b-die? I found a cl16 3600 like $5 more than the 3200.
Also, how important is it for the modules to be on the mobo support list? I am looking at two different ones now and neither are on the supported list.
Thanks.
Thanks.
