Tengis
- Jun 11, 2003
I've been screwing around with this system for a couple days and it gets blue screens regularly... trying to get work done and it crashes when doing something as simple as unzipping a rare file.
CPU has been run with higher voltage and SOC voltage to see if stability gets better. Ram has been run at lower speeds with slightly tweaked voltage to see if stability improves.
I updated the bios but it didn't make a difference.
Any common issues? The bsods I primarily am getting say they are from "memory management".
CPU:
Ryzen 5 2600
Motherboard:
ASRock B450M-HDV R4.0
Ram:
https://www.amazon.com/dp/B07WLCWQV5/ref=cm_sw_r_cp_apap_LRskFFlOczTgZ
CPU:
Ryzen 5 2600
Motherboard:
Ram:
