cybereality
- Mar 22, 2008
Played a few games at 4K with Vega Crossfire at 60 fps or above.Any tl;dr for those of us in the video-averse crowd?
I probably should have mentioned, I adjusted the fan and temp target. RPMs set to 1600/3600 and target at 80C. Otherwise it was not overclocked.I saw your RX Vega are around 70C 75C that is pretty good. Is this the default driver setting ?
Nothing a little overclocking can't fix. CPU from 3.7 to 4.0. GPU to +40% power limit. Crossfire mode to AFR compatible.That is REALLY LOW.
Something isn't working correctly.
