RX 5700 or RX 5700 XT ?
Discussion in 'Video Cards' started by ng4ever, Aug 12, 2019.
  1. ng4ever
    ng4ever Flaccid 4Evar
    1,340
    Feb 18, 2016
  2. ManofGod
    ManofGod [H]ardForum Junkie
    10,650
    Oct 4, 2007
    What monitor? Reference 5700 is good and if you plan on putting under water, that would be the way to go. (I have a 5700 and it plays well at 1440p 144hz Freesync.) Since you are probably going to buy a custom card, I have no idea but, Sapphire is usually the best.
  3. ng4ever
    1,340
    Feb 18, 2016
    ASUS ROG PG279Q 27" Gaming Monitor WQHD 1440p IPS
  4. ManofGod
    10,650
    Oct 4, 2007
    Well, I would say sell the monitor, get a Freesync version and a 5700XT. If you do not want to sell the monitor, get a 2070 Super instead, since the monitor you have is G Sync enabled.
    ng4ever and Maddness like this.
  5. Maddness
    Maddness [H]ard|Gawd
    1,194
    Oct 24, 2014
    Easiest route is to get an RTX 2070 or the 2070 super. Otherwise as above you'll have to sell the monitor if you want to run Freesync. It's a shame you can't enable GSync on and AMD card.
    ng4ever likes this.
  6. 123Lanoix
    123Lanoix 2[H]4U
    3,840
    Nov 13, 2005
    yeah you can run free-sync with RTX2070 but you can't run AMD with g-sync. Makes you wonder how much g-sync premium is worth it in the end ?
  7. Soulwrath
    Soulwrath n00b
    33
    Jun 30, 2014
    1080 Ti used would be good too
    SnowBeast likes this.
  8. DrLobotomy
    DrLobotomy [H]ardness Supreme
    5,822
    May 19, 2016
    5700 with a good aftermarket cooler (air) with all the little finned heatsinks for the memory.
    Maddness likes this.
  9. Soulwrath
    Soulwrath n00b
    33
    Jun 30, 2014
    But what about hang sync monitor
  10. GoldenTiger
    GoldenTiger [H]ard as it Gets
    18,648
    Dec 2, 2004
  11. Maddness
    1,194
    Oct 24, 2014
    That's a good option too.
  12. misterbobby
    misterbobby 2[H]4U
    3,762
    Mar 18, 2014
    5700 XT non reference card if you want AMD or spend a little more and get the 2070 Super.
  13. Soulwrath
    Soulwrath n00b
    33
    Jun 30, 2014
    wish there was a "sad face" button because this is so true T.T
