I would really appreciate any advice on the following setup:
RV042 v.3 gateway in load-balancing mode with 2 adsl lines.
A Tomato Linksys E3000 to handle all DHCP + QoS + bandwidth monitoring + traffic shaping on the lan.
I want to avoid double-nat if possible.
I would like to retain access to the dsl modems' GUI if possible.
I would like the setup to be as secure as possible.
I currently have the RV lan port connected to the wan port of the E3000 using static wan on the E3000.
DHCP is disabled on the RV.
The E3000's wan ip is entered as a DMZ host on the RV
The E3000 has a lan ip on a different subnet than the RV and has DHCP enabled.
The E3000 is in gateway mode because in router mode there is no access to the internet, which means I have double-nat.
The above setup is working for me, but is there a better alternative configuration?
Many thanks!
Many thanks!
