I am currently building a new home and plan on running my own cat5e or cat6e Ethernet cable throughout. Our contractor charges $80 per run and I plan on having at least two runs per room x5 rooms, so running my own cable is going to save me thousands. I am a Network Administrator and have been making my own Ethernet cables for years, but I’ve never run cable through a home being built where I could pre-install as many lines as I wanted before the drywall goes up. This is a unique opportunity because I will be able to make the installation very clean. The problem is that I am not sure how to run the cable through the home.
Examples (what I am not sure about):
1. If I use UTP do I need to drill separate holes through each of the studs (keeping them at least 12 inches away from the electrical lines and outlets to minimize crosstalk?), or can I get away with using STP cable and run it through the same holes as the electrical, or is STP still not going to be enough protection running right along side of the electrical?
2. I’ve heard that stapling Ethernet cable to the studs is not a good idea especially when using solid cable because of the wear. I’ve also heard that this is a bad idea in general because of the increased possibility of crosstalk (from the staple smashing the cables together). I am looking for some confirmation or advice on this one.
3. I would like to use UTP solid cable for all the runs because I hear that as long as I keep them 12 inches away from any electrical and don’t excessively bend the cable that I will get more bang for my buck because UTP is less expensive and the solid cable will give me a stronger signal over longer distances than standard cable. My only concern is that I plan on hooking all of the cable runs straight into a switch rather than a patch panel (where they meet in the basement), so they’re going to potentially get moved around a little more than they would if I wired them to a patch panel. This is my only fear in using solid cable - I don’t want to wear them out or have them break on the switch side of things from moving them around. I could try using standard cable, but again, I understand that standard is best used for short distances because it cannot carry the signal as strong for as long. However, the longest stretch of Ethernet cable in my entire home will run no longer than 100’. How much signal degradation will be lost if I use standard for everything vs. solid at this maximum distance? Will the difference be negligible?
4. I also plan on running Quad shielded Coax cable along side of the Ethernet cable. From what I have read they shouldn’t crosstalk, but I wanted to throw this out there to get a second opinion. Maybe the Coax can be run with the electrical…?
5. I have thought about running cat6e in my home rather than cat5e, but after spending multiple hours researching this online it seems like I would be better off saving the extra $80 and sticking with cat5e. I don’t believe this decision will affect my homes resell value for me because I don’t plan on living there for more than 6 years and I doubt that people will be using 1000mb+ networks at home in that amount of time. That’s my thought. Any additional input is welcome. Let me know what you think is best.
Thanks in advance for any and all replies.
I am looking for technical confirmation, additional thoughts, considerations, and opinions.
SexyJeep
SexyJeep
