Running a bigadv WU in a VM
amdgamer
Hey guys, I was curious as to how I can tell whether I have downloaded a -bigadv WU or not. I think I have things set up properly, so let me detail what i've done as i've had a nightmare trying to figure this out.
I went to that link on -bigadv in Freakys guide which automatically links to the eVGA forums. I went ahead and downloaded VMware 3.0 and downloaded the FAH linux image version 1.2.
I went ahead and installed the VMware and unzipped that linux image to a folder. After installation, I opened the fah6.vmx file inside the folder. I start up the VM and it goes through a menu of stuff. Within the VM, I run the configuration of the linux client by doing
./fah6 -configonly
From there, I make sure that advmethods is set off, and otherwise set it up how I normally do it in the windows SMP client. As for command line stuff, I make sure to set these switches....
-bigadv -smp 8 -verbosity 9
Once I have done setting it up, I start the client manually by typing ./fah6
I see something working, but am not exactly sure how to tell whether it is a bigadv wu or not. I know that bigadv stuf are A2 WU's, but I didn't see it pop up inside the VM.
APOLLO
[H]ard|DCer of the Month - March 2009
Which WU did you receive? There are three possible -bigadv units from the ones I've seen: P2681, 2682 and 2683. All others are not -bigadv WUs.
amdgamer
I got WU 2683. I'm just worried that I didn't set up the client properly. When I tried to do the web setup that was listed on the help page, it kept crashing the client and displayed an error message when I hit the submit button. As a result, I went and set it up manually. So far, it is still at 0%, so i'll see what happens in a while.
tjmagneto
[H]ard DCOTM x2
So far it sounds like you have it good so far. Things to be sure of: passkey is entered and 10 regular WUs are completed.
If you've done all of that I'd give it a while to see what you got. In the meantime here's some code from my most recent download so you can compare what you are seeing to what I have. Please ignore the smp -6 flag BTW. Mad scientist and his pet 980x. Anyway key in on the text and see if you have references to the A2 core and one of the project numbers Apollo has mentioned. I have a 2681 running.
Code:
--- Opening Log file [April 18 22:26:59 UTC]
# Linux Console Edition #######################################################
                       Folding@Home Client Version 6.29
                          http://folding.stanford.edu
Launch directory: /usr/local/fah
Executable: ./fah6
Arguments: -configonly
[22:26:59] - Ask before connecting: No
[22:26:59] - User name: tjmagneto (Team 33)
[22:26:59] - User ID not found locally
[22:26:59] + Requesting User ID from server
[22:26:59] - Machine ID: 1
[22:26:59]
[22:26:59] Configuring Folding@Home...
[22:27:25] - Ask before connecting: No
[22:27:25] - User name: tjmagneto (Team 33)
[22:27:25] - User ID: B0D26F840299DDD
[22:27:25] - Machine ID: 11
[22:27:25]
[22:27:25] -configonly flag given, so exiting.
--- Opening Log file [April 18 22:27:35 UTC]
# Linux SMP Console Edition ###################################################
Executable: ./fah6
Arguments:[B] -bigadv -smp 6 -verbosity 9 [/B]
[22:27:35] - Ask before connecting: No
[22:27:35] - User name: tjmagneto (Team 33)
[22:27:35] - User ID: B0D26F840299DDD
[22:27:35] - Machine ID: 11
[22:27:35]
[22:27:35] Work directory not found. Creating...
[22:27:35] Could not open work queue, generating new queue...
[22:27:35] - Preparing to get new work unit...
[22:27:35] Cleaning up work directory
[22:27:35] - Autosending finished units... [April 18 22:27:35 UTC]
[22:27:35] Trying to send all finished work units
[22:27:35] + Attempting to get work packet
[22:27:35] + No unsent completed units remaining.
[22:27:35] - Autosend completed
[22:27:35] Passkey found
[22:27:35] - Will indicate memory of 4661 MB
[22:27:35] - Connecting to assignment server
[22:27:35] Connecting to http://assign.stanford.edu:8080/
[22:27:35] Posted data.
[22:27:35] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[22:27:35] + News From Folding@Home: Welcome to Folding@Home
[22:27:35] Loaded queue successfully.
[22:27:35] Connecting to http://171.67.108.22:8080/
[22:28:13] Posted data.
[22:28:13] Initial: 0000; - Receiving payload (expected size: 30337609)
[22:28:26] - Downloaded at ~2278 kB/s
[22:28:26] - Averaged speed for that direction ~2278 kB/s
[22:28:26] + Received work.
[22:28:26] + Closed connections
[22:28:26]
[22:28:26] + Processing work unit
[22:28:26] [B]Core required: FahCore_a2.exe[/B]
[22:28:26] Core not found.
[22:28:26] - Core is not present or corrupted.
[22:28:26] - Attempting to download new core...
[22:28:26] + [B]Downloading new core: FahCore_a2.exe[/B]
[22:28:26] Downloading core (/~pande/Linux/AMD64/Core_a2.fah from www.stanford.edu)
[22:28:26] Initial: AFDE; + 10240 bytes downloaded
[22:28:26] Initial: E2DE; + 20480 bytes downloaded
[22:28:26] Initial: 10DD; + 30720 bytes downloaded
[22:28:26] Initial: DB2B; + 40960 bytes downloaded
[22:28:26] Initial: D7C6; + 51200 bytes downloaded
[22:28:26] Initial: 1E5A; + 61440 bytes downloaded
[22:28:26] Initial: 3918; + 71680 bytes downloaded
[22:28:26] Initial: B62D; + 81920 bytes downloaded
[22:28:26] Initial: 8224; + 92160 bytes downloaded
[22:28:26] Initial: 2EF2; + 102400 bytes downloaded
[22:28:26] Initial: 51B3; + 112640 bytes downloaded
[22:28:26] Initial: EEEB; + 122880 bytes downloaded
[22:28:26] Initial: 6BAF; + 133120 bytes downloaded
[22:28:26] Initial: 7619; + 143360 bytes downloaded
[22:28:26] Initial: C379; + 153600 bytes downloaded
[22:28:26] Initial: 0560; + 163840 bytes downloaded
[22:28:26] Initial: AAE6; + 174080 bytes downloaded
[22:28:27] Initial: F473; + 184320 bytes downloaded
[22:28:27] Initial: B49A; + 194560 bytes downloaded
[22:28:27] Initial: B200; + 204800 bytes downloaded
[22:28:27] Initial: AB35; + 215040 bytes downloaded
[22:28:27] Initial: 8CD4; + 225280 bytes downloaded
[22:28:27] Initial: F8D8; + 235520 bytes downloaded
[22:28:27] Initial: F038; + 245760 bytes downloaded
[22:28:27] Initial: 9B45; + 256000 bytes downloaded
[22:28:27] Initial: 240B; + 266240 bytes downloaded
[22:28:27] Initial: 31B3; + 276480 bytes downloaded
[22:28:27] Initial: CDE0; + 286720 bytes downloaded
[22:28:27] Initial: 6796; + 296960 bytes downloaded
[22:28:27] Initial: C0A4; + 307200 bytes downloaded
[22:28:27] Initial: C3D5; + 317440 bytes downloaded
[22:28:27] Initial: A651; + 327680 bytes downloaded
[22:28:27] Initial: B14F; + 337920 bytes downloaded
[22:28:27] Initial: 0B2C; + 348160 bytes downloaded
[22:28:27] Initial: 72C4; + 358400 bytes downloaded
[22:28:27] Initial: 8864; + 368640 bytes downloaded
[22:28:27] Initial: 6D08; + 378880 bytes downloaded
[22:28:27] Initial: 1CF2; + 389120 bytes downloaded
[22:28:27] Initial: 9816; + 399360 bytes downloaded
[22:28:27] Initial: 3EC0; + 409600 bytes downloaded
[22:28:27] Initial: 703A; + 419840 bytes downloaded
[22:28:27] Initial: 09B9; + 430080 bytes downloaded
[22:28:27] Initial: AA0D; + 440320 bytes downloaded
[22:28:27] Initial: 8EAD; + 450560 bytes downloaded
[22:28:27] Initial: 84D4; + 460800 bytes downloaded
[22:28:27] Initial: D6BD; + 471040 bytes downloaded
[22:28:27] Initial: CFD6; + 481280 bytes downloaded
[22:28:27] Initial: F90B; + 491520 bytes downloaded
[22:28:27] Initial: 0ED5; + 501760 bytes downloaded
[22:28:27] Initial: 5391; + 512000 bytes downloaded
[22:28:27] Initial: 191B; + 522240 bytes downloaded
[22:28:27] Initial: E9DA; + 532480 bytes downloaded
[22:28:27] Initial: A5D1; + 542720 bytes downloaded
[22:28:27] Initial: 6280; + 552960 bytes downloaded
[22:28:27] Initial: 65A4; + 563200 bytes downloaded
[22:28:27] Initial: EC84; + 573440 bytes downloaded
[22:28:27] Initial: D490; + 583680 bytes downloaded
[22:28:27] Initial: 81E1; + 593920 bytes downloaded
[22:28:27] Initial: 2F42; + 604160 bytes downloaded
[22:28:27] Initial: F547; + 614400 bytes downloaded
[22:28:27] Initial: C82A; + 624640 bytes downloaded
[22:28:27] Initial: 4470; + 634880 bytes downloaded
[22:28:27] Initial: 1274; + 645120 bytes downloaded
[22:28:27] Initial: 9160; + 655360 bytes downloaded
[22:28:27] Initial: BBE4; + 665600 bytes downloaded
[22:28:27] Initial: 4B2F; + 675840 bytes downloaded
[22:28:27] Initial: 0D9E; + 686080 bytes downloaded
[22:28:27] Initial: 853C; + 696320 bytes downloaded
[22:28:27] Initial: 07C5; + 706560 bytes downloaded
[22:28:27] Initial: 99D1; + 716800 bytes downloaded
[22:28:27] Initial: 3E21; + 727040 bytes downloaded
[22:28:27] Initial: 8D87; + 737280 bytes downloaded
[22:28:27] Initial: 2EE0; + 747520 bytes downloaded
[22:28:27] Initial: 34E8; + 757760 bytes downloaded
[22:28:27] Initial: 7632; + 768000 bytes downloaded
[22:28:27] Initial: 2787; + 778240 bytes downloaded
[22:28:27] Initial: BCF1; + 788480 bytes downloaded
[22:28:27] Initial: 8A69; + 798720 bytes downloaded
[22:28:27] Initial: 89BF; + 808960 bytes downloaded
[22:28:27] Initial: 2FFA; + 819200 bytes downloaded
[22:28:27] Initial: F841; + 829440 bytes downloaded
[22:28:27] Initial: E850; + 839680 bytes downloaded
[22:28:27] Initial: BDA1; + 849920 bytes downloaded
[22:28:27] Initial: 333D; + 860160 bytes downloaded
[22:28:27] Initial: 1468; + 870400 bytes downloaded
[22:28:27] Initial: 8508; + 880640 bytes downloaded
[22:28:27] Initial: 7AE5; + 890880 bytes downloaded
[22:28:27] Initial: FABE; + 901120 bytes downloaded
[22:28:27] Initial: 506E; + 911360 bytes downloaded
[22:28:27] Initial: 7B76; + 921600 bytes downloaded
[22:28:27] Initial: BED4; + 931840 bytes downloaded
[22:28:27] Initial: 37BE; + 942080 bytes downloaded
[22:28:27] Initial: 0000; + 952320 bytes downloaded
[22:28:27] Initial: DAC2; + 962560 bytes downloaded
[22:28:27] Initial: E881; + 972800 bytes downloaded
[22:28:27] Initial: AA55; + 983040 bytes downloaded
[22:28:27] Initial: 4B32; + 993280 bytes downloaded
[22:28:27] Initial: C8F7; + 1003520 bytes downloaded
[22:28:27] Initial: 4982; + 1013760 bytes downloaded
[22:28:27] Initial: 1AA3; + 1024000 bytes downloaded
[22:28:27] Initial: 29FF; + 1034240 bytes downloaded
[22:28:27] Initial: E7F3; + 1044480 bytes downloaded
[22:28:27] Initial: 44C4; + 1054720 bytes downloaded
[22:28:27] Initial: C1F5; + 1064960 bytes downloaded
[22:28:27] Initial: 6E67; + 1075200 bytes downloaded
[22:28:27] Initial: 6CFD; + 1085440 bytes downloaded
[22:28:27] Initial: E016; + 1095680 bytes downloaded
[22:28:27] Initial: 65AA; + 1105920 bytes downloaded
[22:28:27] Initial: 139F; + 1116160 bytes downloaded
[22:28:27] Initial: 297E; + 1126400 bytes downloaded
[22:28:27] Initial: 6E00; + 1136640 bytes downloaded
[22:28:27] Initial: 6AB2; + 1146880 bytes downloaded
[22:28:27] Initial: F6CC; + 1157120 bytes downloaded
[22:28:27] Initial: BD78; + 1167360 bytes downloaded
[22:28:27] Initial: FB0D; + 1177600 bytes downloaded
[22:28:27] Initial: 727B; + 1187840 bytes downloaded
[22:28:27] Initial: DE81; + 1198080 bytes downloaded
[22:28:27] Initial: 8A18; + 1208320 bytes downloaded
[22:28:27] Initial: 5209; + 1218560 bytes downloaded
[22:28:27] Initial: BC2E; + 1228800 bytes downloaded
[22:28:27] Initial: DF52; + 1239040 bytes downloaded
[22:28:27] Initial: B792; + 1249280 bytes downloaded
[22:28:27] Initial: CC73; + 1259520 bytes downloaded
[22:28:27] Initial: 3BD4; + 1269760 bytes downloaded
[22:28:27] Initial: 6B8D; + 1280000 bytes downloaded
[22:28:27] Initial: AC5A; + 1290240 bytes downloaded
[22:28:27] Initial: 113D; + 1300480 bytes downloaded
[22:28:27] Initial: F7B1; + 1310720 bytes downloaded
[22:28:27] Initial: A688; + 1320960 bytes downloaded
[22:28:27] Initial: 5AB0; + 1331200 bytes downloaded
[22:28:27] Initial: D12E; + 1341440 bytes downloaded
[22:28:27] Initial: 78D7; + 1351680 bytes downloaded
[22:28:27] Initial: BB9F; + 1361920 bytes downloaded
[22:28:27] Initial: 5FE3; + 1372160 bytes downloaded
[22:28:27] Initial: BCF0; + 1382400 bytes downloaded
[22:28:27] Initial: 4715; + 1392640 bytes downloaded
[22:28:27] Initial: DA25; + 1402880 bytes downloaded
[22:28:27] Initial: E075; + 1413120 bytes downloaded
[22:28:27] Initial: C420; + 1423360 bytes downloaded
[22:28:27] Initial: 1F10; + 1433600 bytes downloaded
[22:28:27] Initial: CFBB; + 1443840 bytes downloaded
[22:28:27] Initial: EBE0; + 1454080 bytes downloaded
[22:28:27] Initial: B802; + 1464320 bytes downloaded
[22:28:27] Initial: 939D; + 1474560 bytes downloaded
[22:28:27] Initial: 2FFC; + 1484800 bytes downloaded
[22:28:27] Initial: A8EB; + 1495040 bytes downloaded
[22:28:27] Initial: 8DAE; + 1505280 bytes downloaded
[22:28:27] Initial: 98B5; + 1515520 bytes downloaded
[22:28:27] Initial: D5E3; + 1525760 bytes downloaded
[22:28:27] Initial: 8AD3; + 1536000 bytes downloaded
[22:28:27] Initial: 55F7; + 1546240 bytes downloaded
[22:28:27] Initial: EFE9; + 1556480 bytes downloaded
[22:28:27] Initial: 4A95; + 1566720 bytes downloaded
[22:28:27] Initial: 1F6A; + 1576960 bytes downloaded
[22:28:27] Initial: 0822; + 1587200 bytes downloaded
[22:28:27] Initial: CCE6; + 1597440 bytes downloaded
[22:28:27] Initial: 627D; + 1607680 bytes downloaded
[22:28:27] Initial: 2523; + 1617920 bytes downloaded
[22:28:27] Initial: 417A; + 1628160 bytes downloaded
[22:28:27] Initial: A217; + 1638400 bytes downloaded
[22:28:27] Initial: AC37; + 1648640 bytes downloaded
[22:28:27] Initial: CF99; + 1658880 bytes downloaded
[22:28:27] Initial: 36C9; + 1669120 bytes downloaded
[22:28:27] Initial: FE55; + 1679360 bytes downloaded
[22:28:27] Initial: 137B; + 1689600 bytes downloaded
[22:28:27] Initial: B60A; + 1699840 bytes downloaded
[22:28:27] Initial: A6C6; + 1710080 bytes downloaded
[22:28:27] Initial: 7ADB; + 1720320 bytes downloaded
[22:28:27] Initial: 5344; + 1730560 bytes downloaded
[22:28:27] Initial: 4B3D; + 1740800 bytes downloaded
[22:28:27] Initial: 432B; + 1751040 bytes downloaded
[22:28:27] Initial: CCEE; + 1761280 bytes downloaded
[22:28:27] Initial: 6D0A; + 1771520 bytes downloaded
[22:28:27] Initial: 7F9F; + 1781760 bytes downloaded
[22:28:27] Initial: 8423; + 1792000 bytes downloaded
[22:28:27] Initial: 0E16; + 1802240 bytes downloaded
[22:28:27] Initial: 99DD; + 1812480 bytes downloaded
[22:28:27] Initial: A0A4; + 1822720 bytes downloaded
[22:28:27] Initial: FA33; + 1832960 bytes downloaded
[22:28:27] Initial: 0D61; + 1843200 bytes downloaded
[22:28:27] Initial: 1A43; + 1853440 bytes downloaded
[22:28:27] Initial: 5B4C; + 1863680 bytes downloaded
[22:28:27] Initial: AFBF; + 1873920 bytes downloaded
[22:28:27] Initial: 3028; + 1884160 bytes downloaded
[22:28:27] Initial: 0745; + 1894400 bytes downloaded
[22:28:27] Initial: 0EED; + 1904640 bytes downloaded
[22:28:27] Initial: D081; + 1914880 bytes downloaded
[22:28:27] Initial: 201F; + 1925120 bytes downloaded
[22:28:27] Initial: 7EAE; + 1935360 bytes downloaded
[22:28:27] Initial: B210; + 1945600 bytes downloaded
[22:28:27] Initial: 7DE6; + 1955840 bytes downloaded
[22:28:27] Initial: 1001; + 1966080 bytes downloaded
[22:28:27] Initial: 5326; + 1976320 bytes downloaded
[22:28:27] Initial: 0D49; + 1986560 bytes downloaded
[22:28:27] Initial: B065; + 1996800 bytes downloaded
[22:28:27] Initial: 189B; + 2007040 bytes downloaded
[22:28:27] Initial: 43C9; + 2017280 bytes downloaded
[22:28:27] Initial: 597E; + 2027520 bytes downloaded
[22:28:27] Initial: 165F; + 2037760 bytes downloaded
[22:28:27] Initial: 6152; + 2048000 bytes downloaded
[22:28:27] Initial: 9122; + 2058240 bytes downloaded
[22:28:27] Initial: 4E13; + 2068480 bytes downloaded
[22:28:27] Initial: 66B0; + 2078720 bytes downloaded
[22:28:27] Initial: 03D7; + 2088960 bytes downloaded
[22:28:27] Initial: 596C; + 2099200 bytes downloaded
[22:28:27] Initial: CC1C; + 2109440 bytes downloaded
[22:28:27] Initial: 8565; + 2119680 bytes downloaded
[22:28:27] Initial: 45A7; + 2129920 bytes downloaded
[22:28:27] Initial: 74A1; + 2140160 bytes downloaded
[22:28:27] Initial: F3AC; + 2150400 bytes downloaded
[22:28:27] Initial: 118A; + 2160640 bytes downloaded
[22:28:27] Initial: 205A; + 2170880 bytes downloaded
[22:28:27] Initial: 69B3; + 2181120 bytes downloaded
[22:28:27] Initial: A252; + 2191360 bytes downloaded
[22:28:27] Initial: 8454; + 2201600 bytes downloaded
[22:28:27] Initial: FD33; + 2211840 bytes downloaded
[22:28:27] Initial: 2817; + 2222080 bytes downloaded
[22:28:27] Initial: 6625; + 2232320 bytes downloaded
[22:28:27] Initial: F706; + 2242560 bytes downloaded
[22:28:27] Initial: 62A3; + 2252800 bytes downloaded
[22:28:27] Initial: 6E9B; + 2263040 bytes downloaded
[22:28:27] Initial: A98B; + 2273280 bytes downloaded
[22:28:27] Initial: 96AD; + 2283520 bytes downloaded
[22:28:27] Initial: C3A2; + 2293760 bytes downloaded
[22:28:27] Initial: 2E15; + 2304000 bytes downloaded
[22:28:28] Initial: C0BF; + 2314240 bytes downloaded
[22:28:28] Initial: 1836; + 2324480 bytes downloaded
[22:28:28] Initial: 5BE5; + 2334720 bytes downloaded
[22:28:28] Initial: D351; + 2344960 bytes downloaded
[22:28:28] Initial: F418; + 2355200 bytes downloaded
[22:28:28] Initial: FB39; + 2365440 bytes downloaded
[22:28:28] Initial: 2626; + 2375680 bytes downloaded
[22:28:28] Initial: 6D5C; + 2385920 bytes downloaded
[22:28:28] Initial: 7D6C; + 2396160 bytes downloaded
[22:28:28] Initial: 2119; + 2406400 bytes downloaded
[22:28:28] Initial: D8FF; + 2412195 bytes downloaded
[22:28:28] Verifying core Core_a2.fah...
[22:28:28] Signature is VALID
[22:28:28]
[22:28:28] Trying to unzip core FahCore_a2.exe
[22:28:28] Decompressed FahCore_a2.exe (5509624 bytes) successfully
[22:28:28] + Core successfully engaged
[22:28:33]
[22:28:33] + Processing work unit
[22:28:33] [B]Core required: FahCore_a2.exe[/B]
[22:28:33] Core found.
[22:28:33] Working on queue slot 01 [April 18 22:28:33 UTC]
[22:28:33] + Working ...
[22:28:33] - [B]Calling './mpiexec -np 6 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -nice 19 -suffix 01 -checkpoint 15 -verbose -lifeline 1028 -version 629'[/B]
[22:28:33]
[22:28:33] *------------------------------*
[22:28:34] Folding@Home Gromacs SMP Core
[22:28:34] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009)
[22:28:34]
[22:28:34] Preparing to commence simulation
[22:28:34] - Ensuring status. Please wait- Files status OK
[22:28:38] - Expanded 30337097 -> 159726549 (decompressed 101.7 percent)
[22:28:39] Called DecompressByteArray: compressed_data_size=30337097 data_size=159726549, decompressed_data_size=159726549 diff=0
[22:28:40] - Digital signature verified
[22:28:40]
[22:28:40] [B]Project: 2681 (Run 2, Clone 17, Gen 95)[/B]
[22:28:40]
[22:28:40] Assembly optimizations on if available.
[22:28:40] Entering M.D.
[22:28:47] (Run 2, Clone 17, Gen 95)
[22:28:47]
[22:28:47] [B]Entering M.D.[/B]
[23:09:28] [B]pleted 2500 out of 250000 steps  (1%)[/B]
[23:50:22] Completed 5000 out of 250000 steps  (2%)
[00:31:08] Completed 7500 out of 250000 steps  (3%)
[01:11:55] Completed 10000 out of 250000 steps  (4%)
[01:53:08] Completed 12500 out of 250000 steps  (5%)
[02:34:14] Completed 15000 out of 250000 steps  (6%)
[03:15:12] Completed 17500 out of 250000 steps  (7%)
[03:55:50] Completed 20000 out of 250000 steps  (8%)
APOLLO
OK, that is definitely a -bigadv WU so no problem there. I never had a crash from doing the web setup. Assuming the OC is 100% stable, the only other reason I can think of having crashes is insufficient memory allocated for the VM.
amdgamer
I don't think it could be memory as I have allocated 9gigs of ram to the VM during the VM setup. Is there a log file I can fo find? Can't seem to find one when I looked into the folder that the linux image was unzipped to.
APOLLO
That's more than sufficient and nearly double the minimum so no worries. OOC, how mcuh did you install in total, 12GB?
amdgamer
Yeah, I decided to go safe and install a full 12 gigs. If it isn't needed, I figure that I could always remove 6 and use it towards boxen #2 at some point in the DISTANT future :)
After all, DDR3 is probably going to be around for a long time.
tjmagneto
[H]ard DCOTM x2
One way you can get to the log is by opening your web browser and going to //IPAddress/log.php. The IP address is assigned by the VM when you first start it.
amdgamer
Thanks as i'm heading downstairs now to check on things. I'll give this a try, although I wonder whether I might have screwed up by using the -configonly to set it up since the web setup by punching in that http:// crashed on me.
tjmagneto
[H]ard DCOTM x2
When I screwed up my bigadvs this past weekend I kept running into problems due to not paying attention to all sorts of stuff when I restarted them. Somehow I had autostart going and didn't want it to since I'd rather do my own configs once I got my name, team and passkey in from the webpage, or I forgot to change the Machine ID Number from 1 to something else within -configonly as Linux_FAH assigns the VMs to Machine ID 1 and I already had that number assigned to something else.
It took a few looks at one error in the log and a visit to Task Manager before I realized that I was fighting against a job that was already running. I stopped it from the admin page, went back to the config page and turned off the autostart, rebooted the VM and did the rest of the work in -configonly. I sure learned a lot from screwing up!
Good luck.
amdgamer
Thanks!
I just screwed up my first bigadv WU by accident as I simply closed the VM like I would any Internet Explorer window. Bad news is that the WU is messed up and gone :(
For now, I just installed the windows SMP client and will run A3 WU's until I have time to work out a native Linux install. No more of the VMware stuff for me........
I will try to make time this weekend after I get back home from Chicago to do a Ubuntu 9.04 install. Since I am leaving in a couple days, I need whatever is running to be in maximum stability anyway. However I really hope that they hurry up and get Windows SMP clients doing -bigadv for those of us who have been spoiled by GUI's.
APOLLO
Thanks!
If you're using Player 3.0, closing the VM will actually suspend it and therefore preserve its state at the moment of its closing. That is how it functions by default and could mean that your VM was not affected. In any case, you need to complete 10 WUs to be eligible for the bonus. It's faster to run A3 WUs to achieve it.
amdgamer
I actually completed 10 WU's a long time ago. My understanding is that those 10 WU's can be bigadv or regular A3 advmethods WU's. I believe i've comleted close to 20 under my passkey. When I shut down the VM and restarted it, I got a message that the client was unable to retrieve WU and that it was corrupted. As a result, it got rid of it and downloaded a new fresh WU.
I then screwed that up by accident as my computer went to sleep(forgot to turn off power management). When I went to reawake the computer, it was again unable to retreive the WU and discarded it. I am positive I have done something wrong, as I hear that VM is supposed to be easy to use. Until I have time to figure out a native Linux install, I am just going to do SMP windows client for now. I've already messed up 2 bigadv WU's and I don't want to mess any more up as that would take me under the 80% success rate required to recieve them.
tjmagneto
[H]ard DCOTM x2
I've destroyed my share of bigadvs this past weekend, you'll be fine. ;)
There's a setting in the Preferences for VMWare Player you may want to check on to help reduce risk from losing stuff if the VM is closed for whatever reason (like oops I closed the wrong app-been there myself). Go to File>Preferences>When Closing a Virtual Machine and select "Suspend the Virtual Machine." It has saved me a few times where I accidentally closed a VM.
amdgamer
Maybe i'll give it another try, but i'm gonna go do a bunch of SMP A3 WU's for now in order to get my numbers up. Thay way i'll have a larger number of bigadv's I can screw up without dropping below 80%. I also have to get back to my real life as I spent an entire day yesterday stability testing, and I have stuff that desperately needs to be done before I head to Chicago the day after tomarrow.
zero2dash
You really don't need the -verbosity flag. :)
And 5gb of ram to the VM is plenty. ;) No need to give it more. :)
amdgamer
Well, I think i'm goign to give -bigass another try as I think I know what I did wrong! The web setup by entering that IP address into the browser didn't work for me as I got an error. As a result I set up the Linux client manually using the console to set up and start up. However, I was reading those instructions again and I think I might have had problems because I didn't disable the the web service like it says in #8 of the intructions.......
8) If you plan to start the client via the console and plan not to use the web configuration, you can disable the web
service with this command:
web disable
When this HUGE 6040 A3 work unit finishes(it has been taking a very long time), maybe i'll fire up the VM again and give it another shot. I spent part of my tax refund to build this rig and damnit I want it to be as productive as possible :)
amdgamer
Ok, i've got a bigadv going now on my folding rig, so lets see how well it works this time. So far, it is going at a rate of 40-42% of a WU per day. It has been working on it for 12 hours now and is 20% of the way through. Lets hope this works out :) I'm crossing my fingers.
BTW, did anyone notice how freakin huge those 6040 A3 WU's are? It tied up my internet forever uploading and I noticed that it was a 67 mb file.
Kendrak
[H]ard|DCer of the Year 2009
Thus the reason I am seriously thinking of getting a second dsl line.
mplee
I'm trying one now also, in the VM that was linked in the EVGA forums. Seems to be running ok, around 44:15 per frame. It's about 25% complete.
I want to say the bigadv results are around 95MB....I recall seeing that someplace or another.
Kendrak
They are bigg'ens
I'm out in the middle of nowhere so my upload is under 1mb... it takes a while. I'm going to put my (soon to be two) big adv boxen on a second dsl line that also just happens to plug into my main rig :D Wife is going to be abusing Netflix with the baby coming soon, and here being here at the house all day.
amdgamer
I have you beat Kendrak as my upload speeds are horrendously slow. Of the 3 speed packages, I have the middle one offered by Time Warner which limits you to 384kbps upload, and 7mbps download. They have a top of the line one that has 512kbps upload and 14mbps download, but there is no way in HELL i'm going to pay $120 per month for internet access.
I suppose that i'll have to start paying attention to when my folding rig is getting ready to upload before I get on to Xbox Live for multiplayer.
Kendrak
The line I'm looking at is 14.99 and has a 768 down and 384 up. Stick the boxen on that line and let them fight over the bandwidth ;)
amdgamer
Internet is really expensive here in Cincinnati because there is no competition. There is DSL which is absolutely slow and lousy unless you happen to live right next to the routing station. As a result, Time Warner and cable in general has control of the market here. I also tried DSL in my area and reliability was a horrendous problem as the phone lines wern't good enough for a consistent connection. I live in the ghetto so nobody gives a frickin care about the quality of service here. While DSL is cheap, the max speed they could get into my neighborhood if the lines were actually decent would be 512kbps upload/512kbps download.
Kendrak
I used to live just north of Cincy, have a bunch of family there.
Next time I'm out there we should meet up and grad a drink or something.
amdgamer
That sounds like fun. Just let me know and I should almost always be available. I actually hope to get out of the city as it has gone to hell. Cincinnati is quickly becoming the next Detroit.
APOLLO
-bigadv will tie down your connection even more. Many people report upload times of 20 minutes or greater. The positive being these WUs take more than 2 days to complete, so it's not that frequent over the course of a week unless you have several clients.
amdgamer
Since I only have one dedicated folding boxen, at least it will be pretty predictable when it will start uploading. At least that will give me a chance to plan my xbox live gaming sessions. It looks like for me, I will be able to complete a -bigadv every 2.5 days @ 3.67ghz.
amdgamer
Ok, my first -bigadv WU just posted. For 2.7 days worth of folding, it netted me 55k points. I finished with somewere around 54-56% of time remaining(forgot which). I guess I thought i'd be doing a little better than this, but I suppose it beats what running A3 WU's was giving me.
tjmagneto
[H]ard DCOTM x2
Congratulations on your first bigadv. Your points sound about right according the specs you are giving.
APOLLO
Congrats! To improve the bonus credit you will need to increase the OC. I know you have been experiencing limitations doing this but IMO your processor should be capable of higher clocks. If you can get it down to around 2.5 days which is achievable, it would be better.
amdgamer
Thanks guys.....
Considering that my system hard locked on me @ 3.67ghz(now downclocked to 3.57ghz@same Vcore), I think I may have hit my limit in terms of speed and stability with this i7 930. I am just hoping that it is stable at the new 3.57ghz speed. Considering that I had to massively increase voltage to get the clocks over 3.67ghz, I suspect this is around where my chip is at the limit for this batch run of processors. 3.67ghz ran just fine for a few days before crashing, but to get it above this speed required a significant increase in voltage from the 1.2685 to 1.35. This took temperatures into the mid and upper 80's with my case. I did try running my case without the side panel, and it allowed the load temps on the cpu to drop by 6-7 degrees.
I followed a combination of Maximumpc, Cecil, and Tomshardware's overclocking guides for the 920.
So long as I can continue to help our team, i'm happy even if I can't net the big points I thought I could. After all, running a -bigadv in less than 3 days still allows me to get more points than just running A3's all the time. 3.57ghz still isn't bad for a processor that is rated to run at 2.8ghz.........
tjmagneto
[H]ard DCOTM x2
Deja vu all over again.
I was getting low-mid 80s with my i7-920 C0 @3.8 ghz and 2 GPUs running. My cooler was a TRUE 120 and my case was a mid-tower. The same thing with the temps happened to me when I pulled off the side panel, my temps dropped quite a bit so it looked like I was just not getting good overall airflow. I almost put a blowhole in my case but decided to get a new case instead.
Have fun with the bigadvs!
amdgamer
Yes, I need to recharge my "entertainment" budget but I think i'm going to move everything over to a full tower Cooler Master HAF932 case when I do get some more money. This case is just too tight anyway. However, I do like how that case is so nice and light. It is easy to move around while my desktop rig weighs like a ton.
tjmagneto
[H]ard DCOTM x2
I felt a little guilty moving to a full tower but was so easy to install stuff.
amdgamer
That is what I get for trying to be cheap. I should have known that a case that was perfectly adequate for the little heat that those old processors generated wouldn't be adequate for a fire-breather like the Core i7. Damn this thing puts out a lot of heat, and I thought that my Phenom put out a lot of heat. I'm jealous at your 32nm chip :)
tjmagneto
[H]ard DCOTM x2
Two things i7-920s are not when overclocked, in AMD speak: Cool and Quiet. :D
amdgamer
Yeah, I was talking to a fellow church member today and he was shocked that i'm running an overclocked Core i7 in that case. He told me to either fork over money for water cooling, or get a bigger case as those older generation mid-towers are absolutely inadequate for core i7's even at stock speeds.
APOLLO
If that's true, I'd run the system open without panels until you replace it just to be certain nothing overheats or causes other problems like crashing WUs.
