chameleoneel
- Aug 15, 2005
The claim is any game already with regular framegen.So on Rtx 5080 i will able to use that new frame generation on what games?
OkBasically every one that currently supports it it sounds like.
Indeed.
However, some games have frame pacing or hitching issues, or tearing, with framegen. One or more of the pieces of the chain are failing, it seems.
Point being, this stuff is far from perfect. Despite some of its bullish fans.
Frame generation automatically enables Nvidia's reflex, which caps fps at a few fps below your refresh rate.
I love my eye candy too, but frames/smoothness has its own unique benefit to the quality of the image. Like I'm not going to go from 144 FPS to 65 FPS just for slightly better reflections in limited areas.
Interesting, I will have to re-check that. In my experience it never seems to work. Every game I use frame generation on the FPS seems to be unlocked, and regularly goes above my refresh rate (144). I can see it go up to 175 or so. Setting FPS cap in game is unusually disabled, and if enabled in NV control panel it does not seem to work when frame generation is on.
I have a 120hz monitor these days (LG C3), and while I do appreciate a little higher framerate than I used to, I am still an "eye candy first" aficionado. There is just something about good eye candy that can make a good story title even more immersive.
But when it comes to the old 60fps rule of thumb thing, there is something people forget. And that is that back then,m sure we targeted an average of 60fps, but that was because we had v-sync on. The target was an "average" of 60fps only because every single frame was exactly 1/60 of a second (unless you dropped below 60fps, which we didn't want to do.
That is not the same as targeting an average of 60 fps today. An average framerate of 60fps in the G-Sync/Free-Sync/VRR era is MUCH worse than a flat 60fps.
By modern standards the equivalent is more like targeting a 0.1% minimum of 60fps.
And that is completely different. If you target a 0.1% minimum of 60fps, your average tends to wind up in the 90-100fps range, and that I actually tend to find quite acceptable. I'm not going to scoff at more if I can get it, but I am also not going to sacrifice eye candy and immersion in order to do so.
Do you have Vsync on the NV control panel? You should. Gsync works best that way. And so does Reflex.Interesting, I will have to re-check that. In my experience it never seems to work. Every game I use frame generation on the FPS seems to be unlocked, and regularly goes above my refresh rate (144). I can see it go up to 175 or so. Setting FPS cap in game is unusually disabled, and if enabled in NV control panel it does not seem to work when frame generation is on.
I never used vsync, ever, until I started using VRR.
Nah, 4090 will sell at about the same price as a 5080 because of the 24GB VRAM. Maybe slightly less. You won't see $500 4090 for a few more years.$1000 5080's retail.
$500 4090's used
yes, it was clearly announced.Wait i read somewhere specification of Rtx 5080 . And have smaller ROPS,CUDA,TENSORS than 4090 rtx. Is this true? If yes so 4090 will be faster?
ok thx. I think i will buy still 5080. But must wait for prizes. it's enough for me to 1440P, rtx 5080yes, it was clearly announced.
yes. it makes up with software trickery.
you better get the 5090 or youll always doubt if you made the right choice. or better, wait for the 6090 'cause it will be even better!![]()
You can frame cap with frame generation. RTSS does it and IIRC nvidia's limiter was updated to do it too.One thing I did not see mentioned, and I assume has not changed, is that you cannot set a frame rate cap with frame generation. That is a downside of the technology. Often times when I do turn it on it may make scenes where I am getting 80 frame rates look better at 110 or so, but other scenes it pushes above my refresh rate/G-sync limit. And then I see screen tearing. This will probably be a bigger issue with this new iteration of frame generation for many people. I know some monitors have higher refresh rates but those are often still limited to higher end OLED panels.
If I missed that and some how they got frame rate caps to work with frame generation, then that would be excellent news. But it is another reason why I can't get too excited over increases in frame generation performance and why I prefer seeing improvements outside of DLSS/frame generation for native resolution.
Would Nvidia knowingly leaves inefficiencies in its firmware or drivers that it can fix to unlock additional performance, if the market isn't behaving how Nvidia wants, to give itself a PR / competition boost?
oki but with 5090,miniimum 1200W psu? 1000W too weak?dont ask us, ask you local stores. also, buy the 5090.
No.
They have no need or reason to do something like that, their stuff is already king of the hill.
https://seasonic.com/pl/focus-gx-atx-3/
1000W Focus ?
But prime atx 3.1 and pcie 5.1 is not in shops.I'd go prime every time.
Required System Power (W) (5) | 1000 | |
Supplementary Power Connectors | 4x PCIe 8-pin cables (adapter in box) OR 1x 600 W PCIe Gen 5 cable |
She is beautiful.
Them/they it has 2 fans.She is beautiful.
most of them are in the other threads too...for those that aren't much for YouTube, TPU has a unboxing here.
lol great mindsRTX 4090's younger, slimmer, and hotter sister ...
Reviewers scoffed that the new card would be like a radiator and in the end it turned out to be 2 slots.Jensen surprised everyone again.Them/they it has 2 fans.
He's the best tech CEO out there and continues to prove it. Don't listen to the biased clickbait idiots.Reviewers scoffed that the new card would be like a radiator and in the end it turned out to be 2 slots.Jensen surprised everyone again.
We shall see how the 600w card trowing all the heat toward the cpu and memory. The top mounted case fans will be key in dumping all that heat out of the case as fast as possible.Reviewers scoffed that the new card would be like a radiator and in the end it turned out to be 2 slots.Jensen surprised everyone again.
