StoleMyOwnCar
- Sep 30, 2013
Is that intake or exhaust? If that top fan is intake, that's kind of stupid. I can't really see it doing anything valuable. If anything, I think it would have the opposite effect. It probably won't matter with how dumb oversized that heat brick (sorry, heat sink) is. I think if there is a generation where one should opt to go full water, this is probably it. Might as well also invest in super long tubing and put the radiator in another room or something. Maybe pipe it up to the attic (though you would need a pretty strong pump to get it that high)... or hell just put the entire computer in the attic.ASUS ROG Astral 5090 has four fans. Don't think I've seen one like this before, usually there is just a cut out for the 3rd fan.
I actually had an idea for a while about maybe just making an isolated chamber with some cheap piping or tubing leading up to the attic or something. Basically get a bathroom fan above your computer and then isolated so all of the heat will just funnel out into the outside, but it can still draw in air from the inside temps. Might lower AC costs enough to be worth it.
As far as SLI, I used SLI 760 GTXs and 780 GTXs for a while. Wasn't ever quite smooth. It was certainly playable. But not really smooth. Also the issue with the heat buildup between the cards.
