wareyore
HDCOTY 2023
- Jan 1, 2014
Say what?The $10k PC comment was a joke.
His description was scary accurate. Price was way off, but, add a $2k GPU and that gets one 1/4 way there, with tax and whatnot.
The biggest issue is raster fakery costs millions in staffing and development costs, Ray Traced AI fakery costs a few thousand in hardware they had to buy anyways.I have mixed feelings. On one hand, you're correct. Even raster itself employs many tricks to get closer to "life". Shadows, rays, etc. The question has always been about "what's the real deal?" Is raster the complete removal of any "fakery"? No, not really. Raster is a lot of fakery, too (at least afaik). Is "real life" the actual source of truth? Then neither tech is inherently wrong. AI is simply approaching it from a different angle.
Depends what direction you radiator fans are blowing. Most manufacturers say in blowing rad fans because the outside air is going to cool more than inside, hence more efficient as a cooling method, so you could potentially still be blowing that heat inside the caseIt does when you put a water block on it![]()
To summarize all the fake frame nonsense people groaned and complained about last time... well now they're putting in even more fake frames really increasing the artificial FPS numbersSo, to summarize, wait for reviews, gaming may or may not be a good uplift, depending on the settings you use, but, we expect some decent uplift in compute performance?
I was expecting $2,500 for a much more powerful card. I saw that the 7900 XTX could usually be OC’d to 3.2 GHz, so I thought that we would get +20-25% clock speeds in addition to higher core counts and architectural improvements. If I had known that Blackwell would have basically the same thermal limitations as Lovelace, I would have had very different expectations.Everyone is starting to wake up to the fact that the RTX 5090 probably isn't as powerful as everyone wants it to be. It's definitely an iterative performance increase, which is sad considering I've had my RTX 4090 since launch day over 2 years ago.
Which is fine, for those that use it. For others, not so much.To summarize all the fake frame nonsense people groaned and complained about last time... well now they're putting in even more fake frames really increasing the artificial FPS numbers
At which point are the fake frames fake though, changes to DX12 and upcoming changes to Vulkan are going to be providing the GPU with even more data with which it can more accurately generate those framesTo summarize all the fake frame nonsense people groaned and complained about last time... well now they're putting in even more fake frames really increasing the artificial FPS numbers
Right they move enough air that as long as you have some decent flow in and out the difference between them is academic .That is true, but if you have blocks on both your CPU and GPU it barely matters anymore. You can orient those fans either way you want. Blowing in or blowing out, because there won't be any significant heat generating components dumping heat in the case anymore. (though DDR5 and nsome NVMe drives are sure trying to give CPU's and GPU's a run for their money)
Ray Tracing was never about delivering the superior product, it was about delivering 90% of the best raster results for 10% of the cost.
https://www.pcgamesinsider.biz/news/74838/cyberpunk-2077-hits-30m-saleCyberponk 2077 and its ~8M sales
I'd wait on the "2 slot" thing. Many cards are 2 slots, you just can't plug anything into the 3rd slot![]()
My Server GPU's are all 600w 2 slot monsters, I mean no fans on them at all and they rely on the chassis fans to move the air out and through them but hey they are all 2 slot...I'd wait on the "2 slot" thing. Many cards are 2 slots, you just can't plug anything into the 3rd slot![]()
Looks pretty 2-slot to me. I'm not a Linus fan but this was a nice preview.
View: https://www.youtube.com/watch?v=3a8dScJg6O0
And I for one am perfectly content with this. After all, their raster HW is already the best in the world, and the AI fakery actually happens to.... you know... work! It looks good, and dramatically bumps frame rates on 4K+max settings content. They are doing exactly the right things, and as a 4090 owner I am rather excited by the 5090.I talked about it here:
https://hardforum.com/threads/rtx-5...d-overclocking-thread.2038962/post-1046029115
TL;DR, I think with this gen they've given up almost entirely on just raw perf improvements, they're just going all in on AI since that's where their R&D is anyway and also because they probably can't figure out a way to keep up with game demands just using raw HW perf increase anyway. Most of this gen is about increased AI hardware, not raster hardware.
Oh very interesting. I wasn't even tracking this big negative of RT.
I respectfully disagree.Bigger die size with with almost a third more cores, though with a 4-ish percent lower official boost clock, but with significantly wider memory bus and faster memory for a total of nearly 80% more memory bandwidth. Granted most of that bandwidth is probably to supply fake frames for the not-really-AI tensor cores, but I am still interested.
Hating frame generation and upscaling are perfectly reasonable responses, since the images being rendered aren't the real images but approximations. When you buy solid wood furniture, is MDF with a veneer that looks similar to and sometimes even feels similar to actually the same as solid wood planks from the the real hardwood? No. Is it even more galling (pun intended) when the price charged for the MDF is the same as the real wood? Yes.
Alternate example, six and four cylinder cars with sporty aspirations that pump V8 noises through the stereo into the cabin. Are those really just the same as an actual performance V8 of the same vintage?
Fake frames are bad.
Yup, all the pixels on the screen are mathematically calculated either way. The math being used is just different.I respectfully disagree.
Metaphors are great and all, but they can be spun to support precisely the opposite argument. For example solid metal furniture being far more durable than real hardwood. Or six cylinder turbos that make substantially more power than their V8 NA brethren and are, for all practical purposes, better.
Frame generation and upscaling are perfectly viable technologies, particularly at the high resolutions that these GPUs target. It's just a different technique to get to a similar (or superior) end result. After all, let's all be clear that rasterization is "fakery" as well, if you consider ray tracing to be the goal post. And if we've all been happy with rasterization "fakery" for decades now, why are we suddenly offended by AI frame generation?
Again, emphasis, as long as you can plug something into the 3rd slot.
Let me put it this way. Today, to get a 2 slot card, we'd need someone claiming a "one slot" solution.
And with the wattages required, no vapor pipes or liquid metal is going to be really effective/enough, IMHO. So, even if "compact", it's gotta breathe. I'd wait to get too excited. If an "apparent" 2 slot starts appearing in mass from the 3rd parties... then, I'd say "this seems real".
I doubt we will see a Ti model, but I would be interested in a 5080 Super 24GB to upgrade my 3080 Ti.I'm still rocking my 3080ti, depending upon reviews the 5080 seems like a decent upgrade for me...maybe wait on the ti models unless the 5090's are easy to get...LOL
The Vulkan Libraries for DLSS are very interesting to say the least....It's hard to believe they're not going to have more issues with this new version of frame gen as they can't even fix the issues they have right now in the current version. There are still several games where it feels or acts weird when you turn it on. FFS it is broken as hell in Indiana Jones right now with tons of issues and no fix in sight. Even DLSS and DLAA still have issues in lots of games with laughable amounts of ghosting and trailing. In some games you spend more time googling how to fix issues than actually enjoying the game.
I think that's what the TI model will be IMO, a 24GB card with maybe a bump in cores since the gap between the 80 and 90 models is so big.I doubt we will see a Ti model, but I would be interested in a 5080 Super 24GB to upgrade my 3080 Ti.
Who is defending the RTX 5090? Seems like most of this thread is people that are really skeptical about the RTX 5090's actual performance uplift over the 4090. And yes, it can be a prosumer card, but as for the 4090, it is very much a gaming GPU with prosumer features on it. It offered a massive uplift in performance compared to the 3080 and 3090, and when you have a high refresh rate 4K monitor, especially OLED, it is very noticeable.I can't believe none of you guys, or a majority of you have selective memory issues, but the 5090 is literally a TITAN masquerading as a gaming card. PERIOD. While at the same time, Jen Hsun is laughing at you guys while upping the price and some of you actually defend this price! Worst part you're doing it for free.
Between the CUDA core count, VRAM, and tensor cores, literally none of the gamers are going to see the benefits of this. I say this as an arcvhiz artist myself who dabbles in both worlds so it must be frustrated for all the fellow artists in the gaming industry seeing all the hard work they put into textures, lighting, and modeling to see it perverted by AI marketing bullshit and interpolated garbage. It's reductive and lacks inovation. I feel like I've seen this exact bullshit from the 5 years ago only to be regurgitated again. Seriously, it feels like Idiocracy more and more. Feel free to downvote me, but this is the sad truth, but gamers are no longer the customer base, not for a long time now.
I'm one of those people that said my 3080 was good, but then the 4090 turned out to be an absolute monster, so I bought one. If the 5090 turns out the same, I will buy one.It'll be interesting to see how many people acting like they'd never get one in a million years will be posting that they bought one in a month or two. Happened with both the 3090 and 4090.
They mentioned memory efficiency and CPU overhead improvements for frame generation for both the 4000 and 5000 series.
You getting one ?It'll be interesting to see how many people acting like they'd never get one in a million years will be posting that they bought one in a month or two. Happened with both the 3090 and 4090.
See that's part of what I'm talking about is I don't want to have to dick around with stuff that I shouldn't have to in the first place. I mean look at Dead Space as those lazy twats never even cared to fix the ghosting when all it took was a simple newer version. The Last of Us ghosting with DLAA still cannot be fixed no matter what version I use, it still has the issue. And in the Avatar game when I tried to use a newer version that fixed the ghosting it ended up causing other issues after a few minutes of playing that were fixed when I went back to the old dll. I mean I could go on and on but as I said I'm just tired of having to go research what issues can and cannot be fixed.The Vulkan Libraries for DLSS are very interesting to say the least....
The "New Version", is just a major revision on the old version, I mean the current build of DLSS is at 3.8.10 as of Nov 13'th. Just has enough changes to warrant a 4.0.0 rather than a 3.9.0.
Many games with DLSS can get significant improvements from replacing their shipped DLSS.dll file with the new one.
The fact you can just swap out the DLL file to "upgrade" the internal DLSS version the games use is one of the features I do like about it.
But at least with DLSS we can do those things, it's not an option with FSR or XeSS.See that's part of what I'm talking about is I don't want to have to dick around with stuff that I shouldn't have to in the first place. I mean look at Dead Space as those lazy twats never even cared to fix the ghosting when all it took was a simple newer version. The Last of Us ghosting with DLAA still cannot be fixed no matter what version I use, it still has the issue. And in the Avatar game when I tried to use a newer version that fixed the ghosting it ended up causing other issues after a few minutes of playing that were fixed when I went back to the old dll. I mean I could go on and on but as I said I'm just tired of having to go research what issues can and cannot be fixed.
Nvidia's Blackwell flagship GPU uses liquid metal instead of thermal paste to reign in the 575W TGP
https://www.tomshardware.com/pc-com...ead-of-thermal-paste-to-reign-in-the-575w-tgp
Can we please not in commercial products? I'd like my TIM to last more than 3 years.Nvidia's Blackwell flagship GPU uses liquid metal instead of thermal paste to reign in the 575W TGP
You getting one ?
