Rtx 2080 Ti Aorus Waterforce and case
mgty23
mda
He likely means that the liquid AIO cooler's tubing is not long enough to allow you to reach the front of the case where you can mount it. Instead, the tubing is long enough only to reach the top of the case.
mgty23
So i will be able to mount in top of the case? Cpu cooler also is Noctua NH-D15
mda
Should be as long as the tubing is long enough and the D15 doesn't interfere
