This is related to this:
http://hardforum.com/showthread.php?t=1549245
Didn't get much replies there but it is fine, I figured most of it. However, there are some issues that are puzzling me. In one building, we have this draytek vigor 2930 router:
http://www.google.com/#sclient=psy&...=&aql=&oq=&gs_rfai=&psj=1&fp=8d9c50a61d5b9175
and it can emit the signal so that it is working in as an access point. The draytek router was provided by the satellite internet provider. My technician wanted to run a cat5 cable from this router to an access point in another building so that people in the other building can connect to the internet. He actually connected the cable to another wireless router..........or so it seems. Is that doable? What was weird is that in the first building when you connect to the draytek, you get internet but it keeps dropping the connectivity to internet. NOT the wireless connection, that was always on and active, but internet goes away and comes back. And here is the killer, ipconfig says the default gateway is the usual 192.168.1.1. When I type that in my browser, I get into the draytek web interface, BUT NOT all times.........I get into another router the other times !! I was like ???@#%!@?
I'm connected wirelessly to the draytek, so how that happens, I don't know. Internet works when the result of inputting 192.168.1.1 is the draytek interface. When the other router page comes up(linksys), internet goes away. Is this a router conflict? I don't even know if such thing exists! The networking infrastructure was built before I come and tracing the cables is a bit hard. I went and disconnected the cat5 cable going to the other building and all is well.
That was one thing. similar issue is present in another building. We are using a linksys access point to transmit the signal throughout the building. When we connect to the access point, there will be no internet. However, if I take the cat5 cable from the access point and hook it directly to my laptop I'll be online in seconds. The cable is coming from a switch. I tried another access point. Same result. And when I'm connected via the access point and type 192.168.1.1 I can get into two different routers !!! Sounds like the source of internet that is going to the switch is a wireless router, and this router is connected to another router!
That is my reasoning, but I don't know as I'm a noob when it comes to networking.....Have you guys seen something like this?
And why would I get internet if I connect via cable, and not if this cable is hooked to an access point I can wirelessly connect to?
Thanks.
Thanks.
