router problems
psynotic
Hey,
I just got a SMC 7004VBR router and when I installed it my download speeds are totally crap, but when my connection is just straight from cable modem to computer my connection is normal. It seems my router is slowing my speeds down. Can anybody please help me? Thanks!!!
skritch
Originally posted by psynotic
Hey,
I don't have anything specific for you, but you might want to try putting together the simplest possible network (cable modem -> router -> PC), disabling all the features on the router except those absolutely necessary for traffic to flow, and then start turning things back on one by one until you find what's causing the slowdown.
It might also be the cabling. Try new cat5e.
mhenley
why bother with SMC when for the same price (or maybe a dollar or 2 more) you can get a Linksys, the definitave authority in routers. easiest to configure, stable as a rock, and do you ever hear someone complaining about speed issues with a Linksys? i think not.
(oops, is my opinion biased, I think so. Linksys is AWESOME)
lopoetve
No, you'd be complaining of it dropping out every 5 min, requiring the cables to be unplugged and replugged, or the router just not working at all, or DHCP failing... Yeah, Linksys rocks... right...
Cisco is the definitive maker of ANYTHING networking. Period. Get one of those. 3com isn't bad either.
skritch
This is where I point out that Cisco owns LinkSys. :D
ChappyChaps11
well if u are sharing the connection your gunna have decreased speeds as the connection (cable I assume) is what 1.5Mbs? well take that 1.5Mbs divide it by computers
Or if u are just gunna have the connection for one computer get rid of the router
lopoetve
That's only if you are running some kind of controller on the bandwidth (ie: netlimiter) or all systems are loading the network to the max. If there are 10 computers on, and only one is actually doing anything, it'll get the full 1.5mbit.
psynotic
Thanks for the replies guys! By the way i'm sharing my internet connection between two computers.
