Router Bandwidth Monitoring
Discussion in 'Networking & Security' started by unwantedSN, Feb 9, 2010.
  1. unwantedSN
    unwantedSN [H]Lite
    98
    Jan 9, 2009
    Hi guys,
    my Smoothwall died tonight (rip smoothie) so im back to using an old wrt54g. Im looking for a replacement router that can monitor daily/week/month bandwidth for my internet connection. I would install ddwrt on my linksys however it only gives me a total for the entire router and I'd like to have it tell me per IP.
    So does anyone know of a consumer router that can monitor bandwidth like that, or do i need to just pull the trigger and build another smootwall.
    Thanks
  2. spotdog14
    spotdog14 [H]ard|Gawd
    1,297
    Jun 16, 2005
    Tomato does that. I use it all the time, its very nice.
  3. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
    You get some stuff with DD and Tomato, but IMO you've been spoiled by superior offerings, and it's hard to go backwards. Not only for reporting, but..as you'll soon find out, performance that a home grade off the shelf retail product just can't match from that of a good *nix box. I use the BandwidthD plugin for PFSense.
  4. unwantedSN
    unwantedSN [H]Lite
    98
    Jan 9, 2009
  5. keenan
    keenan 2[H]4U
    2,695
    Aug 5, 2009
    These boards are great. I use them often with pfSense NanoBSD.
  6. moetop
    moetop [H]ard|Gawd
    1,471
    Apr 8, 2004
    If your going with a linux distro you can use NTOP. Or even if your keeping the wrt 54g you can run NTOP against the router and monitor traffic. (Search dd-wrt ntop)
    If your running windows do a search for NTop_XTRA_3_18_0.exe they dont make a compiled version for windows and the only place that did doesent support it or have it for download anymore.
