And may I just voice my extreme displeasure at that cable? It's missing wires AND it's wired wrong.
Technically they only require 2 pairs (4 wires) to operate correctly.
yea... should at least start out with orangewhite orange....
EDIT2: and to answer the op's question, that cable probably won't run gigabit... iirc, gigabit sends and recieves on different pair... so to use the actual gigE spec, you need all 4 pairs... pretty much it's only limitation
How cheap ass do you have to be to use a half-duplex 10-BT cable in a world of GigE and PoE? Why didn't they just use a phone handset connector and save some space?.
