What's the direct model number for this case for the Lian-Li version?
Also, does anyone know which side panel fits on this case?
mine rattles like a motherfucker when i put in a cd or when i coldboot it
mine rattles like a mother****** when i put in a cd or when i coldboot it
I replaced a very noisy DVD Rom with a newer samsung that is much quieter. If your optical drives are vibrating like crazy at initial spinup, that could cause some case vibration.
This is the one I ordered:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=280&products_id=1029
I was able to get them to reduce shipping. It charges $30 at first, but I contacted them via email and they reduced it. They said that the computer erroneously calculates it as shipping for the whole case, not just the weight of the side panel only.
Picked one up for $0.07 out the door. Gutted it out and am prepping it for a WC setup!
seven cents. Are you smoking something very powerful?
There is no direct Lian-Li model equivalent for this one.
Looks like the PC-A71 on their web site has the same front door design, judging by the vent holes and the center-mounted lock on the visible right edge.
I thought that too +1
How the heck did you do that ???
Well you may have people on the inside..or something..but how did you do it???
7 cents..open box,broken box..what???
I love this case...just can't stand the raddles. The side panels are secure in th middle b/c the aluminum isn't very thick. I like the look without the door and so I took it off and now its just flat on the front...looks much better IMO
nope...never even heard of that mod
I can't belief I've suffered so long. The case sits on my right hand side and as such, the door always gets in my way. I do actually like the look of the door closed and it's nice to kill the optical drive noise further when ripping. However, I'll never trade temps for aesthetics and that's why the door sits open most of the time.I like the look without the door and so I took it off and now its just flat on the front...looks much better IMO
Is that where one just puts an empty bay in front of the drive w/ sticky tape? I do like the official Lian Li covers because if you do it right, you can push down on the cover and have it close the drive (cause it hits the button).I'll look for the link. If you removed the front panel, you might really like the "invisible optical drive mod". It's magic.
Today I finally looked down and thought, "Hmm...maybe I'll just take it off?" Not only am I getting used to the look, but I no longer have to worry about banging into the thing with my knee or reaching around for the power button!
I'll try and fix the lighting tomorrow for some pics. (cause we need more!!)
Does anyone know which Lian Li transparent side panel and 3x rad top panel will fit this case? I contacted Lian Li and they were far from helpful.
Top: http://www.lian-li.com/v2/en/product/product04.php?cl_index=2&sc_index=10&ss_index=74
Side: http://www.lian-li.com/v2/en/product/product04.php?cl_index=2&sc_index=29&ss_index=73
