EDIT: This has turned into more of a standard OCing thread because it turns out I wasn't as stable as I thought with manual voltages.
Hi All,
The Problem: My 4.7GHz OC is rock solid with manual voltage set. But it crashes when I try to migrate those settings into an adaptive voltage environment.
Please see sig for full system specs.
Rock Solid - Manual Voltages
Hyperthreading OFF
4.7GHz (47 multi)
Cache 4.4GHz (44 multi)
vcore = 1.340
Cache = 1.300v
input = 1.8v
Passed Prime 95 24 Hours Torture Test with 512 minimum FFT while simultaneously looping Valley Benchmark. Max temp is 86c.
Not Stable
When I enable Adaptive voltage, like so. . .
Vcore "Additional Turbo Mode CPU core voltage" = 1.340v
Offset = +.001v (also tried auto)
Cach "Additional Turbo Mode Cache voltage" = 1.300v
input = 1.8v (tried 1.9v too)
. . . Prime95 set exactly as above fails within five minutes despite temps not getting much worse (88c max, again my min FFT is 512k). Sometimes with a reported error and sometimes with "this program needs to close". . .
Also tried setting cache back to auto multiplier so it would (I think) go to 3.9GHz. No effect.
Any advice on dialing in adaptive voltages? I would prefer not to have 1.34v going through my CPU at all times if it can be avoided.
--H
Hi All,
Hyperthreading OFF
4.7GHz (47 multi)
vcore = 1.340
Cache = 1.300v
input = 1.8v
Not Stable
--H
