cantankerous
- Nov 15, 2006
cantankerous said:
CounTDookU23 said:is that a nvidia release on the driver.......... or is it some tweaked version?
Matas said:Maybe there is a possibility to unlock stream processors on 8800GTS with the new Riva...?
jdk said:I ran driver cleaner on the old driver and installed these.. My performance is back up, but I'm not making any judgement just yet as the old drivers would do the same thing after a reinstall (work fine for awhile, then go to shit).
Dan_D said:It hasn't helped in my case. I am still looking at sub Radeon 9600Pro performance out of my $1200 SLi setup on my $300.00 SLi certified motherobard.
Maybe nVidia's driver development team needs a blanket party to get back on track. Their latest drivers are nothing short of a travesty. They are garbage that seems as well polished as you'd expect from alpha level software.
Cyrilix said:I'll agree that nVidia's drivers are the main thing that's holding me back from buying an 8800 GTX right now. To have such a nice hard launch, only to mess it up with drivers that change performance when you boot your computer... what a waste of opportunity to get a perfect launch going.
Domingo said:on a related note, Guru3D also got some new 93 series beta drivers up today, too.
http://forums.guru3d.com/showthread.php?t=205560
I'll might try these out when I get home.
brachy33 said:The 93.81 betas are NOT for the 8800 series cards though, correct?? I think the release notes don't list the 8800s as compatible. I will be very excited, however, to see some half-way decent drivers released for us 8800 series card owners! Please help us good people of nVidia...
I had the same exact problem when the 7800gtx's came out, I got my 3 the same day they were released and had probs with sli due to drivers for about 6 months til better drivers came out, but since you are the mobo editor you should of been aware that nvidia new series releases are always messed up due to drivers for a few months after release. I have 1 8800gtx and it runs great but the drivers are crap, I expected it to some degree but not as bad as they have been especially as a shitload of options are missing in the drivers, that I wasnt prepared for. But I knew when I bought the 8800gtx that it was gonna be a case of messing with drivers for the next 4+ months til I find a leet set.Dan_D said:Really, it's complete bullshit. I don't know whether or not this is because of the motherboard chipset and drivers, or if it's the video card drivers, or even just the combination of the two.
One thing is for certain, with a single card, I got awesome performance with my P5W DH. Since I installed the eVGA 680i, I have seen worse performance.
revenant said:wow.. I didn't have time to play with these drivers last night.. the xmas tree buying and setting up took longer than expected... will hopefully get to that tonight..
Dan_D - so when you go back to single card with your 680i board you still get craptacular performance? that fucking sucks.. man, I am glad I hesitated on that..
str4ng said:Do anyone know if the Source games' fog problem are fixed?
Dan_D said:Another problem I now has is that the nVidia control panel no longer works. I can no longer disable SLi. I'm working on that too.
thespymaster said:I just got my GTX today and have had trouble from the "Get Go". Drivers from the BFG disc didn't install right so, I unistalled them and used nVIDIA's reference drivers. Control Panel will not open, tried 2 sets of betas, Control Panel will not open. Uninstalled, used driver cleaner, re-installed, Control Panel will not open, Uninstalled video drivers, and chipset drivers, used driver cleaner, re-installed everything, Control Panel will not open. Played a little Oblivion, looks good, a little choppy here and there but, I can't modify any driver settings as...you guessed it...Control Panel will not open. If I weren't already bald...I'd be pulling my hair out...
Dan_D said:Heres something to do on your system. I used method 2, and it worked. Be warned, edit the registry at your own risk.
3) Go to Start > Run > and type "regedit"- select HKey Local Machine/System/CurrentControlSet/Control/Video and delete ALL keys. Also go into HKey Local Machine/System/ControlSet001, 002, 003 (if they exist), and delete any keys down the /Control/Video paths similar to above.
