riva tuner and 6600gt?
yea
Edit: BTW you could have just downloaded rivatuner and seen for yourself. It's not like it's a lage file or anything.
i'm placing the order for my college computer here soon so i wanted to make sure riva would work before i hit checkout. but thanks :)
DusterAZ
Rivatuner works for all Nvidia cards going way back. On a 6600GT all it's going to let you do is overclock and modify other driver settings though as there is nothing to unlock.
Unknown-One
Watch out with that 6600GT, if you want to read your temps you 'may' have to manualy edit the cards bios :eek:
I did it, it was easy(ish), it worked, and now I can see that my card is running a little on the warm side :p
kirbyrj
What do you want Riva tuner to do? It's not going to unlock any pipes or anything.
