HardOCP News
[H] News
- Dec 31, 1969
The crew at Overclockers Club have posted a review of the RIOTORO Prism CR1280 today that is certainly worth checking out. The case has a huge side window and has an RGB function that allows you to change the color of the fans.
”I'll start with what I like about the CR1280. The style - while it doesn't break the standard mold for tower cases, it does have a fresh, clean look, and the large side window does it for me. The layout of the top I/O panel is nice too, with adequate spacing of the USB ports (a typical peeve of mine), the separation of the start and reset buttons (another peeve), and the top-facing angle (no USB drives sticking out to get bent over when you walk by). And then there is the size - the CR1280 can handle an extended ATX (eATX) motherboard, supports liquid cooling and long GPUs, and it has decent hard drive capacity.
