Jul 8, 2018 #1 D doug_7506 2[H]4U Joined Oct 17, 2004 Messages 3,247 Just wondering if anyone has come across a led strip that is compatible with the spring gaming 7 motherboard? Something that can just be plugged into its RGB ports.
Jul 11, 2018 #2 T TheMadHatterXxX 2[H]4U Joined Sep 7, 2004 Messages 3,022 You can use any 12v RGB ones... https://www.amazon.com/Phanteks-PH-...=1531325316&sr=8-1&keywords=phantek+led+strip Or if you want something that is individually addressible... https://www.amazon.com/Akasa-Vegas-Magnetic-Light-Strip/dp/B01IBUG8KQ As an Amazon Associate, HardForum may earn from qualifying purchases.
Jul 12, 2018 #3 O Official Gigabyte Verified GBT Rep Joined Dec 19, 2017 Messages 6 Any 4 pin or 5 pin (white or uv) strip should work. If you buy a 4 pin the last pin is simply empty, but it still works. For digital you need a 3 pin connector, many boards use 4 pin (2 pin, skip, pin). Our boards support 5V and 12V via jumper so no worries there. For just normal RGB the light strips are a dime a dozen on amazon.
