Format _C:
- Jun 12, 2001
I rescued another relic from the depths of the garbage man. Anyway I never seen this configuration in a lamp before so that's why I need the help. The configuration is (I take the socket was replaced with a normal 3-way socket because they are easier to find) a socket with no switch and the switch is on the base of the lamp, The switch has 3 wires coming out of it (black, blue, red) and there are 3 wires going up the lamp stem (Red, White, Black) So what type of socket do I need? I want to restore the lamp back to it original beauty First cleaning, Polishing and then rewiring. I know I could take the easy way out and just put a normal socket in it but I rather restore it to its original function
