It's a quirk with Unigine engine. Usually everyone knows to ignore obvious anomalous low fps in this bench. Or like seasoned users let it loop at least once then run it.
AMD, more badass graphics cards please!
You appear to not have been paying attention![]()
Money's better spent (long-term) on a faster Intel or AMD CPU (well, one with more cores), because the iGPU just isn't that fast due to be strapped to a CPU memory controller.
However, if AMD were able to solve that problem in the same socket- shoehorn in HBM?- there's potentially some future-proofing. Just not enough to make it a 'sound' investment unless going dGPU-less is being forced.
Anyone see some high overclocks on the 2400G?. I got mine stable at 4100 Mhz 1.4 volt CPU, 1600Mhz GPU. Haven't had much time with it yet.Voltage was way too high at default, had to manually set. This was a drop in to a previous R5 1600 build on the B350 Tomahawk.
Edit- Do have it under the Deep cool Captain "Overkill" 240EX so far stays under 75C.
Its an awesome 65w 4c/8t CPU. How much more do most people need?
With GPU prices so absurd right now its probably a good investment to get one of these and wait for prices to come back down
Even ignoring the Vega iGpu, how is this $250 cpu/mb setup a bad deal for anyone except ultra-high end gamers who are looking for extreme fps at 1080p?
What would you suggest otherwise?
It may be a while before gpu prices become reasonable so it is still a worthy purchase for those that want to play games now.
When you do upgrade, a 4c/8t Ryzen with a 1070 will handily beat a 6t i5 with a 1060 6gb
My point is I realized I wasn't really their target demo. I wanted more horsepower from both ends of the chip. Decided to go with a beefier CPU and treat the graphics as something of an afterthought.
But imagine if they put out something that really competed with low-end GPUs. Say, a 1050. Man, they would clean up.
I'm probably not their target demographic either.
I figured it would come in around 1030, but was really hoping it would at least be on par with a 1050. Hoping their next iteration could match or surpass that. If the 2400 would have, it would have been a day 1 purchase.
But an Intel 4C/4T will beat a 4C/8T Ryzen, and the 6C/6T Intel will be even faster. With six-core CPUs available and doing as well as their are (AMD or Intel), I can't recommend going any lower, again, unless absolutely necessary.
I'm suggesting that it is a limited platform that will cost you more in the long run. Today, I wouldn't advise building a gaming system in the first place- if your goal is to play games, go buy a console and/or wait until prices recover.
Yes, but you will pay a lot more for it, that's the point, if you're budget limited a 4C/8T Ryzen coupled with a 1070 will be faster than a 4C/4T or even 6C/6T i5 coupled with a 1060, and you'll be paying the same for both if you do a staged upgrade (which you'd be foolish not to right now due to video card prices).
It's pretty silly to recommend 4/4 system...
I'm not- I'm substantiating a claim using a reference of which the 4/4 system is one.
Well good, for you - you are able to read a brochure. That review is nearly a year old btw.
So if a CPU A gets 80 fps in most areas and then 40 fps during combat better than a CPU B that gets 70 fps and only dip down to 60 FPS during combat? "But CPU A has better FPS!!"
In what scenario will a 4/8 AMD actually TRULY make someones gaming experience less than ideal? There are several where a 4/4 Intel will make it stutter.
Try to answer this in a practical manner. I challenge you to have more brain capacity then simply linking FPS charts and actually operate in the "real world". Does this compute?
So no, you were not able to answer the question in a practical sense.
Benchmarks have their merit, you just need to read the data more at times than simply comparing an fps chart.
Still can't keep it professional?
Why are you assuming what I did or didn't do?
I assume you're talking nVidia GPUs, because that's what I was hoping; that I could get something that would at least keep par with my GTX 760 from like late 2012/early 2013, when, IIRC, it wasn't at all top of the line (I don't think I've ever spent more than $250 for a graphics card). Edit: just noticed you talked 1050 after quoting me talking 1050, so yeah, you're talking nVidia GPUs.![]()
Was able to run Cinebench open GL score of 71.7 FPS if I remember correctly. Busy week. Hopefully I have time this weekend.
Edit- got some runs in at 4.175 Ghz 1.4125 volt cpu, Cinebench 913 CPU up to 75.5 temp, 72.28 high OpenGLand it kept dropping on consecutive runs all the way to 60.2 then lockup. Temp was in the 50s. Voltage 1.2 Gfx volts and SOC 1.25. Where should I go from here?
I want this APU for a custom Emulation rig I want to build. The problem is that the cooler for this beast is the size of the case I want to use. Are there any low profile AM4 coolers that would fit a mini-itx case and this board? Slimmer/smaller the better.
