Return of mDTX ... at Asrock
w9gb
Asrock has introduced a series of small Micro ATX motherboards ...
that are close to the Mini-DTX specification: 8.00-in x 6.70-in (203.20 mm x 170.18 mm)
first introduced by AMD in 2007.
https://web.archive.org/web/20090824030803/http://www.dtxpc.org/_docs/42197-DTX_Specification.pdf
Asrock B150M-HDS (2-slots)
Form Factor: 7.5-in x 7.4-in ; 191 mm x 188 mm
http://www.asrock.com/mb/Intel/B150M-HDS/
Asrock B150M-PIO (1 Right Angle PCIe 3.0 x16; 1 Full-size Mini-PCIe)
Form Factor: 8.0-in x 8.3-in, 203 mm x 211 mm
http://www.asrock.com/mb/Intel/B150M-PIO/index.asp
Asrock B150M-PIO2 (1 Right Angle PCIe 3.0 x16, 1 M.2 (Key E))
http://www.asrock.com/mb/Intel/B150M-PIO2/index.asp
For comparison purposes, the Flex ATX specification.
Form Factor, no larger than: 9.0-in × 7.5-inch (English); 229 mm × 191 mm (Metric)
http://www.formfactors.org/developer\specs\FlexATXaddn1_0.pdf
Shuttle XPC motherboards came in a few diferent sizes.
229mm x 191mm
254mm x 185mm
Neapolitan6th
I've really started to love how Asrock has been choosing to do something different even when they don't have to. (Such as pulling off ITX X99)
iFreilicht
Unfortunately, the first board is quite a bit longer than ITX, so it wouldn't fit into most of the cases the do currently support mDTX.
D
Deleted member 89018
Guest
It looks similar (in length at least) to the Shuttle motherboards that go in XPCs. Would work in a bunch of Silverstone's cases too. Although with the x16 slot on the outside it would end up limiting for video cards.
I like the right-angle PCIe slot designs. Those would work really well in the slim tower type enclosures, assuming it lines up in a way where the case isn't expecting some kind of adapter.
StrawKite
I don't understand how the GPU connects. I wish they would show them off in a build.
iFreilicht
Unless you're watercoolilng the GPU. It still limits your options because not all have single slot I/O, but at least in theory you can pack a decent punch in there.
chx
http://www.asrock.com/mb/sticker/100-1-PIO(L).jpg it needs an entirely new chassis, it's lying on the other side of the motherboard. These boards were introduced in 2016 but due to the entirely new chassis requirements they didn't catch on much. I would guess an OEM would like them for a console like PC.
