Return of FX : GA-990FXA-UD7 - OC'd AMD FX 8150 / 6990 Performance Comparison Review
polyzp
PART I of V : Return of AMD FX, Enter Gigabyte
My System:
AMD FX 8150 @ 4.90 Ghz
Promilatech Genesis Cooler - 3 x 135mm Scythe Kama Flex 100CFM fans
Maingear T1000 TIM
8 Gb DDR3 Team Xtreem 2400 cl9 @ @ 1987 Mhz / CL9
Gigabyte GA-990FXA-UD7
XFX HD 6990 + Accelero Twin Turbo Cooler @ 990/1500 Mhz
RevoDrive 3 x2 - 240 Gb​
The first thing that came to mind when I first laid eyes on my new Gigabyte 990FX UD7 board was that it was quite the beautiful board. Much respect for the simple PCIE 16x slot latches, the Crosshair V uses a more traditional type, and sleek heatsink design.
EDIT: It should be noted that I received a revision 1.1 board from Newegg Canada, and that it does have Load Line Calibration (LLC) controls in the bios.
The new Team Xtreem DDR3 ram has a cheap but cool looking reflecting sticker, but what is most appealing are the stats: 2400 Mhz @ Cl9, which is only surpassed by Corsair's grossly overpriced and discontinued Dominator GT dual channel flagship memory.
The memory height is not found online, and could be helpful to potential buyers.
Team Xtreem memory height : 52mm
Promlatech Genesis allowed height: 54mm
So this is awfully close to the tallest ram you could use with this cooler. I have seen Dominator GT ram at a height of 54mm barley fitting underneath the heat sink, found here, and a 53 mm Corsair Vengeance stick here.
Comparison Systems :
AMD FX 8150 @ 4.81 Ghz
Indigo Xtreme TIM
G. Skill 2200 cl7 @ x 2190 Mhz / CL10
ASUS Crosshair V
XFX HD 6990 + Accelero Twin Turbo Cooler @ 990/1500 Mhz​
Intel Rig
Intel i7 3770k @ 4.7-4.9Ghz
Various 8 Gb DDR3
Various Z77 Motherboards
Various GPUs
Results:
Sources:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
Discussion:
We see that for the benchmarks used in Part I of my review, FX only falls signficantly behind when only a single thread is used. When only one core is being used we see a 25-40% benefit per Ghz for the 3770k over the FX 8150.
When all threads can be used, Bulldozer does a good job of making up for the lost single threaded performance. Scaling for FX outshines the i7 3770k by a significant margin. Most notably with techarp's x264 HD, where my FX 8150 @ 4.9 Ghz beats a 5.0 Ghz 2600k, and narrowly loses to a 4.9 Ghz 3770k. (Check source 19)
In TrueCrypt 7.1a we see a 4.9 Ghz FX 8150 performing slightly better than its 22nm 3770k intel counterpart at 4.7 Ghz.
In 7-Zip we see the FX 8150 jumping 2.7 % percent ahead of its 3770k counterpart at the same 4.9 Ghz clock for Compression, but falling behind 2.7% with decompression.
The temperature of a 3770k is also seen to sky-rocket up to 78C during a SuperPi 32m test, while my FX 8150 doest hit above 59C.
Next week well see how my GPU handles graphically intensive workloads on my new Gigabyte board.
Stay Tuned! I am free to answer any questions and also am willing to take any requests you guys might have!
http://AMDFX.blogspot.com
OFaceSIG
That only details to 4.6 unless I'm missing something. Looking to get higher then that.
polyzp
LLC set to very high
Voltage is set at 1.45V
NB at 1.275 V
HT 1.2 V
I haven't tinkered around with other oc settings yet, i simply got 4.9 off the bat, and havent gotten a single blue screen yet running over 40 different tests. Prime 95 will however blue screen at 4.9 and I can only get P95 stable at 4.7 ghz.
Comixbooks
I've been eyeing up that MB for a while in anticipation of Piledriver if it ever comes out =)
Pieter3dnow
Hmm where have I seen this thread before :)
That Revision 1.1 says it all, people been complaining about 1.0 due to crashes.
Kluden
Yeah, I am ok with my v1.0, BUT, the voltage drops and droops are ridiculous. I've never seen anything like it, and it clearly limits stable overclocks and unlocks on my 960T. I bought the board used here on the forums so I didn't pay a great deal for it, so I'm not really complaining. But if I paid retail for version 1.0, and gigabyte wouldn't exchange me a v1.1, I would be livid most likely. Just always read reviews is the moral of my story! :) Its not like v1.0 can't overclock, it definitely CAN, and it can well, but I would say no better than a medium level board. This is the upper echelon board, so I expect more, that's all.
Great review and notes on the V1.1 board here though!
