Researching GPU's for gaming PC build between ( EVGA 3080 Ti 12GB vs. MSI Suprim 3080 Ti 12GB )
Code_Man
Hardforum Team,
I am researching two different GPU's and would like to get opinions on the two choices:
  1. EVGA 3080 TI 12GB
  2. MSI Suprim 3080 Ti 12GB
Can you justify the higher price point for the MSI for a minimal boost to the clocks?
Thanks,
DWolvin
I'd go EVGA just for the (generally) better customer service. The FPS on either will not be different enough to matter. Unless of course you get a golden sample, but that could happen on either one.
Code_Man
evga FTW or XC3?
FTW3 is the one I have on Newegg that I am been monitoring for any price drops or changes. GPU will probably be my last part for the build. Shooting for the fall season unless prices drop even more than they are now.
Ducrider748
To be honest there is no reason to shop for a gpu unless you are ready to buy in week or so. Price,availability and even other newer cards could be available.
To answer.the question I would go EVGA over MSI for the customer service end of the two. MSI makes real good products but there have been issues that have been brought up about their rma as of late.
Code_Man
Good to know CU service goes along way along with warranty programs.
BassTek
If you are targeting fall then I would buy EVGA for the 90 day step up period.
Ducrider748
That will be a good idea if and only if they release to 40xx series. Then they may not have a step up from 30xx to 40xx also.
Thing about the step up program is you pay retail for the stepped up card even if it's on sale. Just a downside to the step up program
OutOfPhase
If there is truly a pick and availability isn't an issue, I'd buy from EVGA as a company.
I'd undervolt whatever i got anyway.
RS_Surge
As an owner of an EVGA RTX 3080 10GB, the only drawback is the heat during load on the GPU.
With 100 % fan curve (yea its loud), it still reaches 82 degrees. Other than that, it's a good card for the price.
My older 1070 and 2080 never got passed 70 degrees with 65% fan curve, so I was a little surprised for high temps during gaming.
alxlwson
You Know Where I Live
You need to copper shim mod
jobert
Surely you have enough sense to know that 82° with the fans at 100% is not normal behavior for that card? I mean literally a few seconds of research shows these cards even on the quiet bios that has the fans putting along would only have temperatures in the low to mid 70s.
sk3tch
I had the MSI GeForce RTX 3080 SUPRIM X 10G - gotta say I was very disappointed with the quality of the cooling for the size of the card (it is MASSIVE). Definitely go EVGA all the way. I have all EVGA cards and I am very happy with their performance and service.
jobert
And I have the opposite experience with EVGA as every single video card that I've ever had issues with has been made by them. I've only had two cards that had constant black screen and they were EVGA. Not to mention those clowns have no idea how to make a fan ramp up and down smoothly. And every issue that I've ever had with their cards is well known and well documented from plenty of others right there on their forums.
RS_Surge
I just bought the card a couple days before commenting about the 3080 and my opinion about it, so yea I should have done some research about undervolting before posting.
Undervolted, and my first attempt was 1906mhz frequency at 868 voltage at with no crashes after playing some BFV and Doom Eternal for a couple days.
The best thing about it was, temps we're no higher than 67 degrees and GPU usage was at 99-100% the whole time with a fan curve of 70%. The fan noise alone is worth it.
Good thing this didn't happen for too long. Just a little under 2 weeks, so I think the health of the card is still fine.
sk3tch
That sucks man! I’d love to see the documentation.
jobert
I think you missed the entire point which is that the card should not be running at those temperatures in the first place even at stock fan speeds never mind the fact that you have the fans at 100%. There's either something wrong with the card or you are using it in some extremely adverse conditions.
RS_Surge
The day that I had in the low 80's, there was a heat wave going around in North America. Typically on a normal day with average weather, it would probably hit 75-76 degrees without undervolting.
Now that I undervolted, and it doesn't hit that anymore. There's nothing wrong with the card. I even tested it in Resident Evil Village and left it laying for an hour without any problems.
I've seen other people post about having that kind of heat without undervolting, so I'm not too worried. I'm pretty sure I have enough cooling to keep it under 70's now from undervolting.
Ducrider748
Not sure how well the Hydro copper stays cool. I'm using a EK Vector block. Let me know how it runs. Been looking at them.
DWolvin
Thanks for reminding me- I forgot to install the Precision software, and that's currently updating my firmware. I'll let you know what I see for temps later.
DWolvin
49c while Foldin@Home, dropped to 40c in about 3 seconds when I paused it. Not too shabby (it's hot in my office right now).
mobusta1
Go with asus tuf. It's an overall cooler card than the evga one. I had that one and ended up returning it for the tuf because of thermals. You can easily throttle on it
Nebulous
Just got it in today. Heavy mofo for sure. At stock, managed Superposition score of 12217 and temps got to 40c. Kombustor just heated it to 42c max. Alot less heat coming off of it compared to my 1080ti FTW3 Hybrid.
