Nerdface Killah
- May 31, 2013
I bought the QuickFire TKL since I thought my K95 was going bad. I got the QF today and saw that it came with wasd key caps. I used the puller and then as I was putting the new red caps on I noticed the caps didn't go on so easily. I pulled out the little booklet that came with the kb and it said to not force the key caps on. However, when I compared the key caps undersides, the + appeared to be slightly smaller different than the key caps that were already installed.
So I tried all different angles to placing the cap on and none helped. I ultimately just had to use a tiny bit of force to push the cap on and then as well when I pushed it down. Did I just break my keyboard? How much force is truly needed? Perhaps I got a defective batch? The + did look a tiny bit smaller than the one that was already installed.
