My gameing machine (see sig) has a TI4200 Asylum card in it.. and the fan on the videocard is getting noisey.
I've cleaned the fan up with some canned-air but it's still getting noisy.. so i figured i should contemplate a replacement before it dies..
What will fit within the confines of the case....
My other system had same problem and i used a copper zalman fanless HS, but for my main gameing machine, something that gets a lot of use, i'd like one with a fan.
thanks...
~jake
thanks...
~jake
