Replacement of the 7670M by GeForce 840M on HP Pavilion G6-2170ec laptop?
Discussion in 'Motherboards' started by postcd, Oct 11, 2018.
  1. postcd
    postcd n00b
    41
    Nov 24, 2016
    Hello,
    i have opportunity to buy HP Pavilion G6-2170ec laptop and i want to ask if it will fit/work to replace its AMD Radeon HD 7670M/2GB by the Nvidia GeForce 840M ?
    Can You link to some website which shows/compares these graphics cards dimensions/socket types so one see whether it will fit regarding the size and whether it will work on that laptop motherboard? I have no idea on how to discover that as i am not a computer tech pro.
  2. Denpepe
    Denpepe Gawd
    918
    Oct 26, 2015
    Afaik laptop GPU's are soldered to the motherboard and can not be replaced, there are some exeptions but they contain desktop GPU's.
  3. defaultluser
    defaultluser I B Smart
    12,125
    Jan 14, 2006
    postcd likes this.
