Replacement monitor stands
Commander FAT
I busted the factory stand for my Acer H243H (damn Call of Duty made me do it I tell ya). It's a little plastic base that snaps onto a vertical pole piece. Does anyone know where I can find parts like this or do I need to buy some sort of generic stand that mounts to the little holes in the back of the display? I already looked on eBay. I saw some Acer stands but none for my model.
check the weight of your monitor before you order that one. if you monitor is too heavy you wont be able to use the height adjustment.
edit: it looks like your monitor is 11.7lbs and the stand i linked has an adjustment for monitors 6-16lbs so your good to go.
