Repairing a bent LGA pin
Discussion in 'Motherboards' started by mnewxcv, Dec 12, 2018.
  1. mnewxcv
    mnewxcv [H]ardness Supreme
    6,186
    Mar 4, 2007
    I recently picked up some free computer parts, among them was a socket 1155 motherboard and cpu. The combo works fine other than the iGPU not showing up at all and no video output to onboard video ports, and it wont see more than 2 dimms. I looked over the board and it looked fine. The socket had 1 bent pin, which was a 'reference' pin. I attempted to repair it today and took a video to share. It is a long one, so watch it on 2x speed if you don't have the time or just jump around. I got the pin somewhat unbent, but unfortunately it was not the solution to either of my 2 problems.
  2. waderunner
    waderunner Gawd
    906
    Jun 2, 2013
    Reminds me of a question I've considered recently... Is it better to have the pins on the CPU (AMD), or the pins on the MB (Intel)? And is there an alternative to pins, other than soldered on?
  3. mnewxcv
    6,186
    Mar 4, 2007
    I prefer amd cpus with pins personally. If I ever bent them, I was able to fix it with a credit card. And you usually don't bend amd pins unless you drop the cpu from a few feet, while intel cpu installation is considered a far more delicate process. I can't fathom how the pin in the video got bent in the first place.
    Brian_B likes this.
  4. Arcygenical
    Arcygenical Will Watercool for Crack
    24,622
    Jun 10, 2005
    I use an insulin syringe and that same USB microscope to repair LGA pins.
  5. mnewxcv
    6,186
    Mar 4, 2007
    I got the microscope as a novelty but it really has come in handy more times than I can recall.
  6. Arcygenical
    24,622
    Jun 10, 2005
    Literally the exact same here. I used it to bypass a VRM circuit on my board that fried. I was able to rebuild it and solder it on using protoboard and copper rails. Really cool.
  7. davidm71
    davidm71 [H]ard|Gawd
    1,410
    Feb 11, 2004
    I just found out that Asus refused my RMA on my motherboard because of bent pins. They wanted $244 to repair it. I could buy a new motherboard for that kind of money!
    Going to repair it myself.
  8. Nenu
    Nenu [H]ardened
    18,270
    Apr 28, 2007
    Same thing years ago, on a brand new board, no warranty.
    A friend used his microscope to try a repair (he's done many repairs like this) but a few were double folded, the board was fkd.
    Put me off Asus for 5 years, I still cant recommend them when they are this shitty, no matter how good their boards are. I have a reputation too!
  9. Master_shake_
    Master_shake_ Little Bitch
    7,072
    Apr 9, 2012
  10. davidm71
    1,410
    Feb 11, 2004
    This is the photo of the socket they sent me:
  11. mnewxcv
    6,186
    Mar 4, 2007
    im not seeing any bent pins...?
    This is not the first time asus has refused rma due to bent pins.... They do it FREQUENTLY on boards sent in with no bent pins.
    davidm71 likes this.
  12. davidm71
    1,410
    Feb 11, 2004
    Yeah they're just making excuses. I bought a newer version in Z270 vs my Z170 refurb for same money. Same line of motherboard.
  13. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    51,387
    May 18, 1997
    Needle nose tweezers that chicks use for their eyebrows and a good magnifying light combo has worked well for me for years.
  14. Kyle_Bennett
    51,387
    May 18, 1997
    I see NOTHING there that would tell me pins are bent.
    mnewxcv likes this.
  15. davidm71
    1,410
    Feb 11, 2004
    There might be a slight slant to them but using a credit card edge would straighten them up? I barely see it myself.
  16. mnewxcv
    6,186
    Mar 4, 2007
    the slant is by design, I dont see anything that could be called damaged. I would reply to them and say you see nothing wrong with that socket, and ask for more specifics. What problem was your system having that made you RMA it?
  17. Susquehannock
    Susquehannock 2[H]4U
    3,081
    Jul 26, 2005
    ha ... you people and your fancy tools. I had to settle for a jeweler's loupe and plastic dental pick, but they were nowhere near the fish hook like that pin. How does that happen?
  18. davidm71
    1,410
    Feb 11, 2004
    The Displayport on MB would blink on and off. Tested monitor on other pc to rule out monitor. Also board had issues with posting to correct gpu in the past and usb ports were flaky not always working.
  19. davidm71
    1,410
    Feb 11, 2004
    I
    I got dental loupes w/ 3X magnification myself!
    Susquehannock likes this.
  20. Furious_Styles
    Furious_Styles Gawd
    939
    Jan 16, 2013
    Couple tips for OP (I've done many pin repairs) Remove the socket clamp completely to give you more room to maneuver. I usually use jeweler's glasses and tweezers, this particular repair probably would have taken less than 5mins. I'm not sure that pin is making proper contact but if it is sorry to hear it did not fix your problem.
    If anyone has a board that needs repairs don't hesitate to PM me.
    mnewxcv and Susquehannock like this.
  21. Spun Ducky
    Spun Ducky Limp Gawd
    493
    Feb 1, 2009
    I use a digital microscope for light bent pins and my olympus stereo microscope for the trainwreck cases. Those tools along with surgical tweezers make it easy but the majority can be done with a simple magnifier and mechanical pencil. A little bit of heat from a hot air gun can also make the pins a bit easier to reshape.
    Falkentyne likes this.
  22. janas19
    janas19 [H]ard|Gawd
    1,403
    Jan 20, 2012
    Did you do a hard CMOS reset to factory defaults? Pull out the CMOS battery for 24 hours?
  23. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    52,513
    Feb 9, 2002
    I prefer the LGA socket design. To this day I still occasionally pull a water block and the Ryzen CPU comes right out with it. These CPU's cost a lot more than some of these if not most of these motherboards. I'd rather trash the board than the CPU if something goes wrong. That said, I've used the tweezer trick Kyle mentioned a few times. You can also do it with a very small mechanical pencil. You can usually manipulate the bent pin with that. It works better on AMD CPU's than Intel sockets. My girlfriend thought it was strange the first time I asked for her tweezers given that I typically don't use tweezers for grooming. I use vice grips for plucking hairs. You can pull more at once with a larger surface area. :D
    Hefty hefty hefty!
    Wimpy wimpy wimpy.
    toast0, davidm71, Spun Ducky and 2 others like this.
  24. Susquehannock
    3,081
    Jul 26, 2005
    Well played. That trash bag TV commercial reference takes me back.
  25. davidm71
    1,410
    Feb 11, 2004
    After speaking with Asus on the phone for 20 minutes and counting pins they disclosed which pins were bent. I still can't tell. Circled them for your amusement.
    I guess Asus would do anything not to honor a warranty. Unbelievable.
  26. Nenu
    Nenu [H]ardened
    18,270
    Apr 28, 2007
    Yep.
    Contact your local politician.
    If this is all it takes for a warranty to be invalidated then the product is not fit for sale.
    SticKx911 likes this.
  27. davidm71
    1,410
    Feb 11, 2004
    I'll just file a BBB complaint against them. Got to wait to receive the board in the mail first.
    Sorry to op by hijacking thread. Similar issue.
    Nenu likes this.
  28. mnewxcv
    6,186
    Mar 4, 2007
    get the fuck out of here. Wow.
    Falkentyne and davidm71 like this.
  29. mnewxcv
    6,186
    Mar 4, 2007
    definitely didn't have the right tools for the job, but got the pin unbent in the end. If I ever have to do it again I will definitely pick up some jewelers tools.
  30. Susquehannock
    3,081
    Jul 26, 2005
    Sheesh. Maybe if those two pins were bent downward slightly. Even that should be visible.
    Small hand-held 10x works for me. Bit of time and wallah. Free X58 board with no more memory errors or dropped slots.
  31. Furious_Styles
    Furious_Styles Gawd
    939
    Jan 16, 2013
    Asus is garbage and your exact scenario is why I refuse to buy any products from them. Dealing with their support team was a joke.
  32. cdabc123
    cdabc123 2[H]4U
    2,125
    Jun 21, 2016
    i never had issues bending back bent pins, i would just use my phone camra as a magnifying glass and either a knife or exacto knife to push the pins back.
  33. elite.mafia
    elite.mafia Broke Back [H]
    10,638
    Aug 23, 2004
    Did you ship that board with the socket protector installed? If it wasn't installed, they will refuse the warranty.
  34. davidm71
    1,410
    Feb 11, 2004
    Language! Wtf! Lol... Asus is also a four letter word in my book!
  35. davidm71
    1,410
    Feb 11, 2004
    Whats a socket protector? That plastic insert that comes with a bran new board? No.
    Can I file a claim with the shipper I wonder...
    Thanks
  36. elite.mafia
    10,638
    Aug 23, 2004
    The socket protector is the little plastic insert that comes with your board, usually they have a label saying not to discard and to use for shipping the board. The board was shipped without it, your warranty is void... Your fault for not reading the terms of service!
  37. davidm71
    1,410
    Feb 11, 2004
    Well I bought the same board in Z270 chipset to replace the Z170 board for same money they wanted to repair it. Going to put it up for sale on ebay. Maybe I'll get a $100 for it.
    Thanks
  38. Gavian
    Gavian Limp Gawd
    315
    Jan 13, 2016
    My friend gave me a dead Gigabyte B8 Gaming board yesterday. He said it had multiple bent pins. I went ahead and straightened the pins, installed my spare i3 6320 and surprisingly it worked.
  39. davidm71
    1,410
    Feb 11, 2004
    I've always wanted to do a coffee lake conversion mod though. Maybe I'll do that instead.
  40. elite.mafia
    10,638
    Aug 23, 2004
    Sorry if I missed it but what was wrong with the board that made you RMA it?
