Renew to BitDefender 2017 or move to Symantec Premium 2017 ?
Discussion in 'Networking & Security' started by TechLarry, Oct 22, 2016.
  1. TechLarry
    TechLarry Can't find the G Spot
    29,276
    Aug 9, 2005
    My BD sub expires soon. Trying to decide whether I should switch to Norton 2017. It's my understanding that Norton is no longer the grand POS it used to be.
    What say you?
  2. TechLarry
    29,276
    Aug 9, 2005
  3. klank
    klank Killer of Killer NIC Threadz
    2,132
    Aug 22, 2011
    Norton will always be a grand piece of shit. Bitdefender isn't much better.
    Eset is a better choice.
  4. Monkey34
    Monkey34 [H]ardness Supreme
    4,961
    Apr 11, 2003
    Bitdefender scored higher than Norton/Symantec on both the home and business fronts in the last av-test.org
    Bitdefender also score as a top player at av-comparatives.org ..... Norton as usual excluded themselves from the testing; since like 2012. They say it's because they disagree with their testing methodology.
    Seems a clear choice to me.
  5. FlangeMonkey
    FlangeMonkey Limp Gawd
    159
    Sep 11, 2010
    If your talking for Home, I would not go Symantec. Enterprise is a different story IMO and a different use case. I haven't used it, but I have people that have deployed several BitDefender in enterprise but I am unsure were the line is between its Home and Enterprise counterparts. Symantec line has normally been quite fare and I use it in enterprise but never for home use.
    That being said, I would suggest looking at Kaspersky.
  6. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
    We've switched most of our SMB clients over to BitDefender (via N-Able). I gotta say....we love it. We were a big Eset partner...but in the past 5 years Btdefender has climbed to the top (take a look at the very neutral and real world testing done at av-comparatives.org). We've experienced less problems with Bitdefender as far as infections, as well as less problems with false positives, and issues with servers and LOB apps. I've only had 1x issue with an application, a client that's a metal fab shop, their waterjet software (which doesn't like any antivirus at all).
