Recently my Lian Li case has started to hum, and I found the part of the case that seems to be bringing this upon me it is the top (ceiling). The temporary solution I've done to muffle/remove the vibration/hum is by putting a 365 day calendar on top and that seems to do the trick.
What can I do to muffle/remove the hum but also not interfere with my temps or having to use one of those sticky adhesive pads that will ruin my Lian Li if I try to take it off in the future?
(Case is stock, no modifications have been done to the top so it's just a sheet of metal)
