Brothernod
- Sep 29, 2001
Doing windows updates and installing service packs on a computer at work on Friday I ran into a problem. The updates were done so I went to restore it's normal login procedure which is to login automatically to a user account (local). The problem is that when it restarted and went to auto sign in an error came up saying something to the effect that the registry was to small and that I needed to increase the registry size and then a counter counted down till a restart of the login process.
It's stuck in this infinite loop and I have yet to figure out how to get out.
Last Good Config didn't work.
a soft reinstall didn't fix it.
Safe mode didn't fix it.
I believe i need a way to force it to let me get the login screen back so I can login as the administrator but I have no idea how to do that.
Any ideas or help would be greatly appreciated.
