WickedWeasel
- Jul 13, 2004
Regcleaner 4.3.780 works on WinXP SP1, but it doesn't run on SP2. After installation, and starting it, it just does nothing. I can see it running in task manager, but nothing is happening. Later on, I set it to run on Win98 compatibility mode, but each time it starts, it initializes like it was running for the very first time.
The single feature that I really like about this program is the "AGE" column. Whenever I install a new program, it indicates all the "new" vs. "old" entries made.
Is there a new program out there that will work on WinXP SP2 that also has the "AGE" column?
Has the registry structure changed so much in SP2 ?
EDIT
found it. jv16 has the equivalent, but it is called software manager instead of regcleaner.
EDIT
