I'm looking at factory-refurbished GPUs again - this time of the refurbished sort. (Why refurbished? I've actually had good luck with them - my current GPU is a refurb, and it's WAY outlasted the warranty.)
The choice is between the Visiontek R9 290 (NOT 290X) and the blower-cooled (also factory-refurbished) GTX770. Both support DX12; however, I have no idea if either supports 4K (later display upgrade). The GTX is $20USD pricier; both are at the same MicroCenter where I bought my current GPU - Rockville, MD. Power requirements are a great big non-issue - so are display drivers (definitively in the case of the GTX770, as I am running the current 365.10 drivers). Which has the best bang for the DX12 buck?
Also (completely separate question), which one supports 4K (if either)?
