Guys/Gals,
I'll be taking an assessment test for a job interview soon.
The details are explained in this quote:
(bolded the important part)
My question is, does anyone know a good reference site to refresh my programming skills. I want to mostly work my answers in the 2nd set in pseudo code or c.
Thanks,
Tordek
Assessment Details
There are 3 assessments:
· The first is a logic-based expression evaluation set. It tells you about a set of operators (like +, -, >, < but more string based) and then asks multiple choice questions based on these assumptions.
· The second set of questions is paper-and-pencil based programming exercise. You may use any of the following languages: C, C++, C#, Pascal, BASIC, Visual BASIC or JAVA. We are focusing on logic and problem solving, not syntax, which is why we also accept pseudo code.
· Part three is a section on Math and Logic. It contains basic math and algebra problems, logic problems, and word puzzles.
You’re evaluated on both speed and accuracy- therefore there is no time limit, but speed is a factor
Expect to spend 2-3 hours to complete the materials
You do not need to study for any of the assessments
Thanks,
Tordek
