rEFInd, 10.11.5 and Kali
xCWolf
So I've had Kali on my mac for a while, decided to update to 10.11 from like 10.9 or something been a while since I updated. I went to delete the old partition Kali was installed on so I could extend it and for some reason I can't delete the old partitions? disk utility seems like it has far less options since 10.9
I think I caught the dumb anyone know why I can't delete these partitions?
EDIT:
Apparently i did catch the dumb. I figured it out
Archer1212
Yeah, the 10.11 disk utility is really simplified compared to 10.10 and older.
What did you do to fix the issue? I have a mac with a partition I can't delete either.
xCWolf
reformat it to something like fat and than you can delete the section and extended the partition
