TheBlackAngel
- Jun 3, 2004
Are your temps while gaming getting out of hand? Regardless, grab a $10 set of low profile BGA ramsinks. That'll rule out overheated memory. And make sure the HSF is clean and free from dust bunnies trapping heat. What cooler is on the card? VF700 or 830?
While playing WoW, according to nvidia's temp monitor program, the temps never get above 55c. The cooler is the original one before the revision, so i would guess the VF700. I have a 120mm fan in the side panel that points directly at the card, but its on a fan controller usually set to low. I will try cranking that up to high and see if that helps as well.
