Reddit's patch for Cyberpunk 2077 yields double-digit performance gains on AMD CPUs
Silentbob343
Red Falcon
From the original Reddit posts:
  • Download HXD or another hex editor
  • Start HXD and File -> Open ... the exe which is located in Steam\steamapps\common\Cyberpunk 2077\bin
  • Open up Search -> Go to ...
  • Look for 02A816B0
  • Locate the above mentioned chars
  • Switch the 75 to a EB
  • Save the exe after the change
mnewxcv
  • Look for 02A816B0
how the hell did someone figure that out
Zarathustra[H]
Extremely [H]
Probably won't make a difference for me ( :p ) but cool find!
I'm hoping that is an oversight, and not an Intel bribe to sabotage AMD performance on the years most hyped title.
ManofGod
Well, I applied the fix and I am sure it has helped with my 3700X and 3600. However, I am enjoying the game so much that I have not even bothered using an FPS meter. I did the same with RDR2, once I did a couple of benchmark runs.
erek
Yes, one post 120 of a thread for a game play trailer. Just in case someone hadn't seen that post.
yah, but people have gotten in trouble for making threads outside of posts already made is why i brought it up
socK
It's ironically from an old piece of code in an AMD library that I guess they used to set the number of worker threads. If it sees an AMD processor that isn't bulldozer, it sets a lower number.
blackmomba
Does it ? People in other threads mentioned seeing cpu usage go up but no perceived improvement in performance
Where are the studies
Red Falcon
If you skim through the original Reddit thread, there are a lot of users pointing out higher CPU usage and around 10-15 fps boosts in general.
Maybe it isn't a hard fact, but it is generally trending that way, which is a definite positive.
Lakados
If the internet is to be believed if you are running a 3700x or lower you will see some gains but anything bigger than that and you will see increased usage but no real gains or in some cases a drop as it over works some cores but leaves others untouched.
wizzi01
Yep, I have been playing before this fix with my 3700x and 1080ti on ultra at 2560x1440 and it was good. I put an fps counter up for s&g and I was shocked I was at 38-44fps. It seemed a lot smoother than that.
DukenukemX
I haven't played the game before this patch but since I've started the game I've had no performance issues what so ever.
blackmomba
Wife is playing on a R5 2600 and RX 580, Powercolor red devil. I can hear the demons being exercised from 2 floors away. I just repasted her too
I'm gonna ask her to try this hack to see what happens
